Using createBafflesDict to create cyclic baffle |
Farzad Faraji
Rep Power: 7 ![]() |
Dear friends
Previously, I have used createBafflesDict to create a thin wall and it worked, but when I used this created wall to inject particles, It cant inject particles. Bases on this I want to try to create "cyclic baffle", but I do not know how to generate "neighbourPatch", then I want to use this cyclic baffle to inject particles to my domain. Note that, my main purpose is to inject particles in somewhere close to middle of my domain. Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object createBafflesDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // Whether to convert internal faces only (so leave boundary faces intact). // This is only relevant if your face selection type can pick up boundary // faces. internalFacesOnly true; // Example using "blades" as name of baffle patch baffles { baffles // group name { //- Use predefined faceZone to select faces and orientation. type faceZone; //faceZone; zoneName BubblePlXXFaceZone; //blades; patches { master { name blades; // patch name type cyclic; neighbourPatch *****; } slave { $master; } } } } // ************************************************************************* // Thanks, Farzad |
#2 | |
Max
Rep Power: 6 ![]() |
Hello Farzad, If I have understood your intention correctly, then you can also use a CellZoneInjection for the injection of the particles, whereby your cell zone must then have the shape of a cylinder. For example you can draw the necessary CellZone in blender, import it as an .stl and define it as a CellZone using snappyHexMesh. |
createbafflesdict, cyclic, injection |
[mesh manipulation] checkMesh error after createBafflesDict | sunagra27 | OpenFOAM Meshing & Mesh Conversion | 1 | October 17, 2020 08:00 |
Possible to create cyliner baffle (internal) using topoSet or stl Mesh? | keepfit | OpenFOAM | 4 | February 19, 2017 14:40 |
[Other] How to create baffle? | Elham | OpenFOAM Meshing & Mesh Conversion | 3 | March 6, 2016 11:37 |
[ANSYS Meshing] ICEM CFD create mesh for OpenFoam cyclic | danilo | ANSYS Meshing & Geometry | 0 | August 14, 2012 05:58 |
[blockMesh] Include list of points | Hikachu | OpenFOAM Meshing & Mesh Conversion | 0 | June 20, 2011 09:03 |
