toposet- cellSet has size 0
Like Tree2Likes
  • 1 Post By Yann
  • 1 Post By fidu
Old   November 2, 2020, 05:17
Default toposet- cellSet has size 0
David
fidu is on a distinguished road
Hi foamers
I want to include a stl file in my case so that I can use it as a porous media later on. However as soon as I run topoSet I get a cellSet with the size 0. The stl file should be ok and closed, so I don't know what I did wrong... Does anyone know what I have to change?
When I run topoSet I get this output:
|  \\    /   O peration     | Version:  v1806                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.com                      |
Build  : v1806
Arch   : "LSB;label=32;scalar=64"
Exec   : topoSet
Date   : Nov 02 2020
Time   : 10:10:01
Host   : "eu-login-13"
PID    : 12700
I/O    : uncollated
Case   : /cluster/scratch/kaeserd/01.11/tree_in_buildings
nProcs : 1
trapFpe: Floating point exception trapping enabled (FOAM_SIGFPE).
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading topoSetDict
Time = 0
    mesh not changed.
Created cellSet trees
    Applying source surfaceToCell
    Adding cells in relation to surface "constant/triSurface/trees.stl" ...
    Marked inside/outside using surface orientation in = 0.26 s
    cellSet trees now size 0
End
my topoSetDict is:
   \\    /   O peration     | Website:  https://openfoam.org
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      topoSetDict;
actions
        name    trees;
        type    cellSet;
        action  new;
        source  surfaceToCell;
        sourceInfo
            file  "constant/triSurface/trees.stl";
            useSurfaceOrientation true;  // use closed surface inside/outside
                                          // test (ignores includeCut,
                                          // outsidePoints)
            outsidePoints   ((-99 -99 -99));    // definition of outside
            includeCut      false;               // cells cut by surface
            includeInside   true;               // cells not on outside of surf
            includeOutside  false;              // cells on outside of surf
            nearDistance    -1;                 // cells with centre near surf
                                                // (set to -1 if not used)
            curvature       -100;               // cells within nearDistance
                                                // and near surf curvature
                                                // (set to -100 if not used)
My workflow so far was:
  1. blockMesh
  2. surfaceFeatureExtract
  3. snappyHexMesh -overwrite
  4. topoSet
Many thanks already in advance for time and help. I hope this problem was not already discussed or if it was you could point me to he tread.
Best
David
fidu is offline   Reply With Quote
Old   November 2, 2020, 07:53
RGS
Rohit George Sebastian
RGS is on a distinguished road
I think the problem here is that you are using an STL file. Doesn't OpenFOAM require meshes in it's own format?
RGS is offline   Reply With Quote
Old   November 2, 2020, 09:09
Yann
Yann will become famous soon enoughYann will become famous soon enough
SurfaceToCell is indeed meant to be used with a STL file as a source.
Here is the documentation for OpenFOAM-v2006 : https://www.openfoam.com/documentati...aceToCell.html
I am not sure what is going on with fidu's error. topoSet gets the file and do the operation without any error so it seems there is no syntax error in topoSetDict. The workflow is fine too.
What you can do :
  • Open the mesh with paraview and open your trees.stl file :
    • Check if the STL file is properly positioned and scaled inside your mesh.
    • Do you have cells entirely contained inside the volume defined by your STL file? (with your setup topoSet will keep only the cells inside the STL)
  • Run surfaceCheck on your STL files to check for any error. I think topoSet would fail if the STL was not closed but you can always check.
Hope this helps,
Yann
fidu likes this.
Yann is online now   Reply With Quote
Old   November 2, 2020, 14:25
David
What you can do :
Hope this helps,
Yann
Thanks a lot! I did not have a fine enough mesh to capture the stl file.
Best
fidu
Yann likes this.
cellset, cellzone, pre-proccessing, toposet, toposetdict
topoSet and splitMeshRegions amod_kumar OpenFOAM Pre-Processing 0 July 10, 2017 09:54
using chemkin JMDag2004 OpenFOAM Pre-Processing 2 March 8, 2016 23:38
topoSet geometry than more than 1 box Grimoli OpenFOAM Pre-Processing 1 April 14, 2013 09:54
[ICEM] Help with fixing imported IGES model siw ANSYS Meshing & Geometry 24 August 24, 2010 12:22
