Turbulent Inlet Condition
Like Tree1Likes
  • 1 Post By HPE
Old   April 9, 2020, 08:49
Default Turbulent Inlet Condition
Ann-Sophie
an.so is on a distinguished road
Hey all
I have run the tutorial case "surface mounted cube". Since this worked I now wanted to increase the delta value for the turbulent boundary condition turbulentDFSEMInlet in the U file.
My Problem: when i change the delta value, the velocity field does not change. Has somebody already had the same problem or can you help me? (I'm not that experienced with OpenFOAM )
I'm thankful for every answers!
an.so is offline   Reply With Quote
Old   April 11, 2020, 18:08
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
does not change the instantaneous or time-averaged velocity field?
which velocity field?
which output parameter should be expected to be changed by changing delta?
HPE is offline   Reply With Quote
Old   April 13, 2020, 05:39
Ann-Sophie
Thanks for your answer!
I implemented sample file which extracts for each time step the transient velocity at certain points in the velocity field. These values don't change.
And it would be the target/hope that you can influence the transient velocity with the delta value.
Or is there another or better way to influence the transient velocity with the turbulent DFSEM inlet?
Old   April 13, 2020, 10:26
HPE
HPE's Avatar
What do you mean by the `influence`?
Could you please restate your question, if possible?
Old   April 13, 2020, 10:35
Ann-Sophie
Finally I want to examine the turbulence properties, like the turbulent kinetic energy, therefor I need the velocity. I would like to know how much these properties change, if I change the turbulent inlet parameters, like the delta value.
Old   April 13, 2020, 16:08
HPE
HPE's Avatar
I think `delta` is something like a characteristic length scale of the domain/flow. For example, for smooth-wall plane channel flow, it would be the half wall-normal height. I would refer to the original paper, or the implementation: here to understand what each variable means.
The most important determinants of the output of this BC are, I would say: R, L, and U, which respectively are Reynolds stress symmetric tensor, integral length scale(s) and time-averaged reference velocity.
kooki_13 likes this.
Old   April 23, 2020, 05:02
Ann-Sophie
Thanks you a lot for your help. Not it is working
Old   April 1, 2022, 10:37
kooki_13 is on a distinguished road
Hi HPE
I want to simulate turbulent jet flow. Would you kindly tell me what is characteristic and integral length scale then?
kooki_13 is offline   Reply With Quote
turbulent inlet, tutorial case
Looping over all faces within a boundary condition (turbulent inlet development) Sevex OpenFOAM Programming & Development 5 September 8, 2016 14:58
Inlet turbulent boundary condition: external flows ROOZBEH FLUENT 3 August 28, 2015 16:34
Pressure Inlet Boundary Condition Issue zoeburton1987 FLUENT 0 May 15, 2012 10:20
How to set up the inlet boundary condition for a low pressure case? beastieboys6 FLUENT 3 April 10, 2012 23:46
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
