February 26, 2020, 06:51 |
Scotch decomposition error
Hello everyone,
I've been trying to decompose my 2-D Mesh using scotch. Unfortunately every cell gets distributed to the same processor 0. The remaining 3 processors wont get any cells. Did this happen to anyone else? I'd appreciate any kind of help. - Mirko Code:
Calculating distribution of cells Selecting decompositionMethod scotch Finished decomposition in 0.01 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 14400 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 29820 Processor 1 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Processor 2 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Processor 3 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Number of processor faces = 0 Max number of cells = 14400 (300% above average 3600) Max number of processor patches = 0 (-100% above average 1) Max number of faces between processors = 0 (-100% above average 1) Time = 0 Processor 0: field transfer Processor 1: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 330 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 335 no cells in mesh Processor 2: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 330 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 335 no cells in mesh Processor 3: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 330 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 335 no cells in mesh Code:
numberOfSubdomains 4; method scotch; scotchCoeffs { processorWeights ( 1 1 1 1 ); } manualCoeffs { dataFile "cellDist"; } simpleCoeffs { n (2 2 1); delta 0.001; } distributed no; roots ( ); |
April 7, 2020, 02:46 |
I assume you didn't get a reply because there is not enough information to see an "error" in your input files... Did you solve it? Otherwise you may want to share your full decomposeParDict... |
April 7, 2020, 15:36 |
Agustín Villa
Rep Power: 15 |
I found the same error in OpenFOAM-7. This is my decomposeParDict: Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 4; method scotch; // ************************************************************************* // Code:
Decomposing mesh region0 Create mesh Calculating distribution of cells Foam::decompositionMethod::New { numberOfSubdomains 4; method scotch; } Selecting decompositionMethod scotch Finished decomposition in 0.1 s Calculating original mesh data Distributing cells to processors Distributing faces to processors Distributing points to processors Constructing processor meshes Processor 0 Number of cells = 147456 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 297248 Processor 1 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Processor 2 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Processor 3 Number of cells = 0 Number of processor patches = 0 Number of processor faces = 0 Number of boundary faces = 0 Number of processor faces = 0 Max number of cells = 147456 (300% above average 36864) Max number of processor patches = 0 (-100% above average 1) Max number of faces between processors = 0 (-100% above average 1) Time = 0 Processor 0: field transfer Processor 1: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 332 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 337 no cells in mesh Processor 2: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 332 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 337 no cells in mesh Processor 3: field transfer --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 332 no points in mesh --> FOAM Warning : From function Foam::polyMesh::polyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 337 no cells in mesh End Have you found any solution? |
July 1, 2020, 18:03 |
Josh McCraney
Rep Power: 9 |
Here's what my decomposeParDict looks like for 16 cores and it runs fine:
numberOfSubdomains 16; method scotch; simpleCoeffs { n ( 4 4 1 ); delta 0.001; } hierarchicalCoeffs { n ( 1 1 1 ); delta 0.001; order xyz; } scotchCoeffs { processorWeights ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ); } metisCoeffs { processorWeights ( 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 1 ); } manualCoeffs { dataFile ""; } distributed no; roots ( ); |
July 9, 2021, 04:52 |
Rep Power: 5 |
Hi guys, did you solve that issue? I'm getting the same errors in my decomposition. Never had that before while I used the ESI-Versions (v1906, v1912, v2006) of OF. Now that I changed to the foundation version (v7) I get this error:
"Processor 47: field transfer --> FOAM Warning : From function Foam:olyMesh:olyMesh(const Foam::IOobject&) in file meshes/polyMesh/polyMesh.C at line 332 no points in mesh" ...for multiple processors in my decomposePar-log. I checked my whole geometry many times, but I couldn't see anything getting wrong. Does anyone have any suggestions or already solved that issue? I just used method simple for decomposition of a 2D-mesh on 48 cores with simpleCoeffs: n (4 12 1) and delta 0.001. |
July 10, 2021, 22:29 |
I've seen errors happen for simple/hierarchical if you have much more cells in the center of your domain as on the edges, but I haven't identified the source of the more general 0 cells problem. You can try the tips of Mark Olesen: parallel decomposition method in openfoam
July 12, 2021, 02:49 |
Rep Power: 5 |
Hello Louis,
thanks for your fast reply! I think i just managed this issue. Somehow the cht-Solver of the foundation-version has a problem by using simple method. I just needed to change to hierarchial, which is almost the same. I couldn't imagine before, that simple method was the problem, because it is the most common used and easiest method. Well.. changing versions is not that trivial anymore it seems . But thank you again for your advice . |
decompose, mesh 2d, scotch |
[OpenFOAM.org] compile error in dynamicMesh and thermophysicalModels libraries | NickG | OpenFOAM Installation | 3 | December 30, 2019 00:21 |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 09:00 |
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh | gschaider | OpenFOAM Community Contributions | 300 | October 29, 2014 18:00 |
ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 06:42 |
DecomposePar links against liblamso0 with OpenMPI | jens_klostermann | OpenFOAM Bugs | 11 | June 28, 2007 17:51 |
