Heated wall by radiation
Like Tree1Likes
  • 1 Post By simrego
Old   February 17, 2020, 09:47
Default Heated wall by radiation
Yann Guyot
YannGuyot is on a distinguished road
Dear all,
I have a question that i suppose quiet simple but I can not find the answer.
I would like to know what type of boundary condition for temperature i should apply to a wall that is heated by a high heat source (like fire) emitting radiation?
I am able to compute the radiation flux received by the wall (with fvDOM) but I don't know how to make it heat my wall.
If any of you know how to simulate this in OpenFOAM i will really appreciate.
All the best,
Yann
YannGuyot is offline   Reply With Quote
Old   February 17, 2020, 17:28
Peter Hess
peterhess is on a distinguished road
Hello!
I am not sure to understand your question right way...
Anyway, see the pdf here:
http://www.nextfoam.co.kr/lib/downlo...bb43ccfe025b25
and look to 4.8.
Regards
Peter
peterhess is offline   Reply With Quote
Old   February 18, 2020, 06:59
anonymous
simrego is on a distinguished road
Hi!
You can use the following BC for example:
https://openfoam.com/documentation/g...d.html#details
For example you can use in flux mode with 0 prescribed flux. Thus your wall will be adiabatic.
This BC will create a heat flux BC based on the radiative field and you prescribed flux, thus: qwall = qPrescribed + qRad
So it will "put back" the radiative flux to the wall.
mezomatic likes this.
simrego is offline   Reply With Quote
Old   February 18, 2020, 08:45
Yann Guyot
Hello
Thank you very much for your replies,
I actually tried this BC (externalWallHeatFluxTemperature) with zero flux, but my simulations were crashing, and i didn't understand why.
Do you have working examples using this type of BC?
Cheers
Yann
Old   February 18, 2020, 09:04
anonymous
Hi!
Sorry, now I don't have a shareable case. But if your temperature blows up, you can try to relax it in the bc somehow like this, but maybe the radiation relaxation is enough and you don't need the temperature relaxation.
Also you can decrease the relaxation of the radiative field if you feel that it will help.
<patchName>
    type            externalWallHeatFluxTemperature;
    mode            flux;
    q               0;
    kappaMethod     fluidThermo;
    qr              qr;
    relaxation      0.7;            //Temperature relaxation
    qrRelaxation    0.7;            //Radiation relaxation
    value           $internalField;
Old   February 18, 2020, 09:23
Yann Guyot
Thank you very much, I will try it and keep you in touch!
Old   February 19, 2020, 06:06
Yann Guyot
It works!
I tried with simulations looking like those from comsol tutorial (min 14:30) https://www.comsol.com/video/simulat...l-multiphysics
Simulation parameters are not exactly the same but I did it in a way that i could see a difference with or without this BC.
I removed the relaxation on temperature since results where physically wrong.
        mode            flux;
        q               0;
        qr              qr;
        qrRelaxation    0.7;
Thank very much for your help
All the best
Natural convection in a closed domain STILL NEEDING help! Yr0gErG FLUENT 4 December 2, 2019 01:04
Enhanced Wall Treatment paduchev FLUENT 24 January 8, 2018 12:55
How model radiation of both solid wall and fluid£¿ Harry Qiu FLUENT 2 February 4, 2013 00:04
External Radiation Boundary Condition (Two sided wall), Grid Interface CFD XUE FLUENT 0 July 8, 2010 07:49
Radiation between heated rods lego Main CFD Forum 1 November 13, 2003 09:39
