Difference using MRFProperties or DynamicMeshDict |
Carlo_P
Rep Power: 8 ![]() |
Hey guys,
I would to understand the difference is uisng MRFPRoperties or DynamicMeshDict in order to simulate a rotating pump. In some tutorial the MRFProperties file is used, insted of other that use DynamicMeshDict. I'd like to use CFMesh for meshing and apply the rotaitng zone using topoSetDict, with simpleFoam solver Which way is the best one? Thanks a lot, Carlo |
Kmeti Rao
Hi Carlo,
dynamicMeshDict is required for the transient dynamic simulation(propeller turorial in pimpleFoam). It demands huge computational efforts. MRF SimpleFoam is a reasonable alternative to transient dynamic simulation. As of now I am simulating my propeller using simpleFoam with MRF and I am also defining the rotating regions using topoSetDict. So simpleFoam with MRF would be the best option out of two. Regards, Krao |
Carlo_P
Thanks a lot for the explanation!
Cheers, Carlo |
dynamicmeshdict, mrf, mrfproperties |
Simulating a flapping airfoil by Fluent which the phase difference equals to 90 | ronak | ANSYS | 1 | March 26, 2020 13:24 |
Difference between dynamicMeshDict - dynamicMeshDict.sixDoF | Marc Batlle | OpenFOAM Pre-Processing | 1 | August 16, 2017 11:50 |
I can't understand the moving function of "libfvMotionSolver.so" in dynamicMeshDict | Jung hoo | OpenFOAM Programming & Development | 0 | July 13, 2016 03:36 |
[snappyHexMesh] snappyHexMesh and cyclic boundaries | Ruli | OpenFOAM Meshing & Mesh Conversion | 2 | December 9, 2013 06:51 |
the effect of upwind difference | hades | Main CFD Forum | 8 | March 14, 2009 23:43 |
