May 17, 2019, 00:44 |
Outlet BC inside fluid domain
Helvines Aquino
Rep Power: 10 |
Dear all,
I have a model like simpleFoam/windAroundBuildings with the same inlet and outlet BC, but there is a heat-exchanger building inside the domain. This building has some fans which functioned as compressors. To make the mesh simpler, is it possible to draw the fans just as circle planes and outlet is applied as BC? Any suggestions will be very helpful. Thank you in advance. |
May 19, 2019, 18:55 |
Rep Power: 15 |
It sounds like you want a momentum/energy source inside your domain. You can do this with fvOptions -- look for "momentumSource" or "energySource" in the code.
Caelan |
May 20, 2019, 22:17 |
Helvines Aquino
Rep Power: 10 |
Do you mean I have to insert fvOptions in system/controlDict? Or do I have to modify the solver?
May 20, 2019, 23:22 |
Rep Power: 15 |
If the solver is built to use fvOptions (ie equations have fvOptions as a source term), then you do not need to modify the solver. If a file called "fvOptions" exists -- in constant or system, depending on OF version I think -- then the solver will read it (and some sort of message will be displayed in the terminal or log) and apply the chosen option. Try searching the tutorials for "scalarSemiImplicitSource" or "vectorSemiImplicitSource" for examples.
Caelan |
Difficulty in calculating angular velocity of Savonius turbine simulation | alfaruk | CFX | 14 | March 17, 2017 07:08 |
Sudden increase the residual of Maxwell's equations | hsezsz | CFX | 2 | October 13, 2016 07:58 |
Velocity vector in impeller passage | ngoc_tran_bao | CFX | 24 | May 3, 2016 22:16 |
[ANSYS Meshing] Solid inside Fluid - Multizone meshing | supercolli | ANSYS Meshing & Geometry | 2 | July 9, 2014 14:20 |
Floating point exception: Zero divide | liladhar | CFX | 11 | December 16, 2013 05:07 |
