results with unknown font
Like Tree3Likes
  • 1 Post By guin
  • 1 Post By guin
  • 1 Post By guin
Old   January 3, 2019, 10:11
Default results with unknown font
Sama
Samsam2 is on a distinguished road
I got my simulation reults, but problem is that I can not read them:
dimensions [0 2 -2 0 0 0 0];
internalField nonuniform List<scalar>
5963410
(?0E?5v?ɡ8+?5b|?@I{ٹ?C ,?Vm?xl?&!o?)>{?0]?nK/?v,d?!5v?F*]XC?0¿?LG'O?;?%PD??2 ?&4<?2k?#? 'l?f}V֢?( ?!߫?f՞?QK׵?oD
?梉(*? ?WU?=v?o<-?D?FAsЦ?x$?%K?WUIֺ? ??
Has anyone same problem? How can I solve this problem.
Thanks for your time!
Samsam2 is offline   Reply With Quote
Old   January 3, 2019, 10:43
Rodrigo
guin is on a distinguished road
Quick tip/idea:
- Open system/controlDict and ensure you have following selection
writeFormat     ascii;
writeCompression uncompressed;
Samsam2 likes this.
guin is offline   Reply With Quote
Old   January 3, 2019, 10:50
Sama
Hello guin,
Thank you for your tip. write format is binary and write compression is off. I changed them as you told. should I run simulation again? because after change I didnt see any difference in results.
Thanks!
Old   January 3, 2019, 10:55
Rodrigo
But, please, be careful!
If your mesh has actually 5963410 elements (as it seems from your post) disabling compression may increase a lot the disk demand for your results. Ensure that you have enough free space in your disk before restarting the simulation. Alternatively, you can just write out results using a longer interval or take advantage of purgeWrite keyword (more info at https://cfd.direct/openfoam/user-guide/v6-controldict/)
Samsam2 likes this.
Old   January 3, 2019, 11:01
Rodrigo
Originally Posted by Samsam2 View Post
Hello guin,
Thanks!
Yes. If your simulation takes too long and you are only interested in the last results, you can resume it from the last time and let it run for a single additional timestep e.g. (again in system/controlDict):
startFrom       latestTime;
stopAt            writeNow;
Samsam2 likes this.
Old   January 3, 2019, 11:30
Smile
Sama
Thank you so much!!
It perfectly works.
font, openfoam, results, strange
[Commercial meshers] fluent3DMeshToFoam bego OpenFOAM Meshing & Mesh Conversion 31 August 16, 2023 10:04
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
Error Message after wmake tH3f0rC3 OpenFOAM 2 July 15, 2011 02:22
forrtl: severe (174): SIGSEGV, segmentation fault occurred therockyy FLOW-3D 7 January 19, 2011 23:52
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 05:23
