chtMultiRegionFoam - defining thermal properties in a solid composite |
November 5, 2018, 04:41 |
#1 | |
Adam
Rep Power: 7 |
I found this forum while troubleshooting a few of my OpenFoam issues and have finally hit one that I haven't been able to resolve on my own. I am having trouble defining the thermal properties of my physical regions in OpenFoam version 5 and was hoping that someone might be able to point me in the right direction. Problem Statement I would like to model the transient heat transfer in a composite material comprised of cylindrical fibres in a matrix. As the fibres are perpendicular to the heat flow, this is a 2D simulation. The two materials have different heat conductivity/density/heat capacity. We assume that these properties don't vary with temperature, and for the moment, would like to assume zero thermal resistance at the interface. Meshing and BCs I have made the mesh using gmsh, with two physical volumes and a shared physical surface to represent the interface. The front and back planes are empty, while the top/bottom are zeroGradient and the left/right sides are at a fixed temperature. I have defined initial and boundary (compressible::turbulentTemperatureCoupledBaffleMix ed;) conditions in the 0/ directory. When I run the follwing, everything looks normal in Paraview. Code:
gmshToFoam splitMeshRegions -cellZonesOnly -overwrite My constant/regionProperties are defined as Code:
regions ( fluid () solid (matrix fibres) ); I am unsure of how to modify the constant\fibres\thermophysicalProperties and constant\matrix\thermophysicalProperties dictionaries. I have found solidProperties files in the src\thermophysicalModels\thermophysicalProperties\ solidProperties\ directory but I don't see how to use/modify them. Is it possible to directly define the solid properties? Or do I need to define a thermoType based on the user guide's section on ThermoPhysical Models? If I try to run chtMultRegionFoam using the following thermoType in the thermophysicalProperties dictionary, I get an error. Code:
thermoType { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } Quote:
Edit: I tried defining the pressure as a constant everywhere in 0/fibres/p and 0/matrix/p now the simulation runs with the thermophysicalProperties defined as: Code:
thermoType { type heSolidThermo; mixture pureMixture; transport constIso; thermo hConst; equationOfState rhoConst; specie specie; energy sensibleEnthalpy; } mixture { specie { molWeight 1; } transport { kappa 80; } thermodynamics { Hf 0; Cp 450; } equationOfState { rho 8000; } } Last edited by Adam_K; November 5, 2018 at 06:02. |
problem defining material properties as a function of temperature | Ehsan301 | CFX | 3 | October 19, 2017 16:33 |
Problem in setting Boundary Condition | Madhatter92 | CFX | 12 | January 12, 2016 04:39 |
defining solid and fluid in chtMultiregionFoam | R_21 | OpenFOAM Running, Solving & CFD | 2 | July 1, 2015 10:54 |
Compression stoke is giving higher pressure than calculated | nickjuana | CFX | 62 | May 19, 2015 13:32 |
Info: Short Course On Thermal Design of Electronic Equipment | Arnold Free | Main CFD Forum | 0 | August 10, 1999 10:18 |
