multiRegionFoam with only solid regions
Like Tree1Likes
  • 1 Post By tobiasS
Old   October 18, 2018, 10:58
Default multiRegionFoam with only solid regions
stockzahn's Avatar
stockzahn is on a distinguished road
Ahoi,
I started to work with OpenFOAM and unfortunately I'm not sure about several problems: If it's me (most probably) or something else. I hope to be able develop my skills fast to contribute to this forum, but for now unfortunately I only have questions.
I would like to use chtMultiRegionFoam to calcuate the heat transfer of an electromagnet. In the end the system will consist of several solid and fluid regions. For starters I wanted to simulate only several solid regions with Dirichelt- or Neumann-BCs and progress afterwards with the fluid regions when I had a working model of the inner solid regions. However, when my model consists only of solid regions, chtMultiRegionFoam complains that it cannot find a fluid region:
--> FOAM FATAL ERROR:
fluid not found in table. Valid entries: 1(solid)
When I implement a fluid region it works. Now I wanted to ask if it is possible to circumvent the introduction of a (useless, but disturbing) fluid region and to get the solver running only with solid regions?
Thanks,
stockzahn
stockzahn is offline   Reply With Quote
Old   October 18, 2018, 11:25
tobiasS's Avatar
Hussam
tobiasS is on a distinguished road
Hallo Stockzahn,
You have to use the old form of regionProperties.. I mean the one of version 5.0 for example. Then you will have no problem calculating only solids. It goes so:
regions
fluid ()
solid (your solid region/s)
stockzahn likes this.
tobiasS is offline   Reply With Quote
Old   October 18, 2018, 11:32
stockzahn's Avatar
Thanks a lot! I was using foamSetupCHT to generate the region folders from templates and it changes the regionProperties to
1( solid X ( solidregions ))
I just have to change it back.
chtmultiregionfoam, only solid regions
problem with Min/max rho tH3f0rC3 OpenFOAM 8 July 31, 2019 10:48
conjugate heat transfer in OpenFOAM skuznet OpenFOAM Running, Solving & CFD 99 March 16, 2017 06:07
properties of solid mixture Ahmed Khattab OpenFOAM 0 December 26, 2012 14:59
Modelling adjacent fluid and solid regions Mary2788 ANSYS Meshing & Geometry 0 June 30, 2011 07:11
CFX4.3 -build analysis form Chie Min CFX 5 July 13, 2001 00:19
