time-varying bc: "scale-time"
Like Tree4Likes
  • 2 Post By rgrune
  • 2 Post By Marpole
Old   July 30, 2018, 14:54
Default time-varying bc: "scale-time"
rgrune is on a distinguished road
I have the OpenFOAM-5.0 and I want to create a wave with the "setWaves tool". I'm following the wave tutorial (/multiphase/interFoam/laminar/wave). It's by default setting up with the Airy wave model for the velocity, where the U specifications for the left side are as below:
left
type waveVelocity;
origin (0 0 0);
direction (1 0 0);
speed 2;
waves
Airy
length 300;
amplitude 2.5;
phase 0;
angle 0;
scale table ((1200 1) (1800 0))
crossScale constant 1;
It supposed that a wave is created from the left side with the specified parameters. The "scale" function (that in this case is involved with "table" function), define a time-varying boundary condition, but I don't know how it works. I searched in the OpenFOAM-Userguide and for "table" function is understood there are two inputs (time1 value1) (time2 value2). For this case they are (1200 1) (1800 0), I guess 1200 and 1800 are times (according to the description of the Userguide), however in the original case the time is set up until 200 seconds, then it doesn't make sense for me, but the case works so I think that has another meaning. I don't know what crossScale means eather. I looked at the waveVelocityFvPatchVectorField.H (that remains in /opt/openfoam5/src/waves/derivedFvPatchFields/waveVelocity), where a description is showned:
Description
This boundary condition provides a waveVelocity condition. This sets the
velocity to that specified by a superposition of wave models. The
corresponding phase fraction condition looks this condition up and re-uses
the wave modelling.
Usage
\table
Property | Description | Req'd? | Default
origin | origin of the wave coordinate system | yes |
direction | direction of the mean flow | yes |
speed | speed of the mean flow | yes |
waves | list of wave models to superimpose | yes |
scale | scale factor along the mean flow direction | no | None
crossScale | scale factor across the mean flow direction | no | None
phi | Name of the flux field | no | phi
\endtable
I find that that description it's not enough to understand how scale and crossScale work.
When I ran the simulation, it looks good, but when I change the some values in the brackets of table, the results of the simulation becomes strange.
I would appreciate if someone knows anything about this matter.
minh khang and ahparvin like this.
rgrune is offline   Reply With Quote
Old   March 30, 2019, 21:05
Default not time-varying bc, but position-varying initial condition
Charles
Marpole is on a distinguished road
Not sure if you find answer. But here is an explanation of how to use the scale.
The table is not time a varying table but a position varying table. It means, before x=1200 meter, the scale is 1, and, after x = 1800 meter, the scale is 0 (i.e. no wave), and in between 1200 and 1800, the scale is a ramp from 1 to 0 (i.e. wave is damping out within 600 meters).
minh khang and zyfsoton like this.
Marpole is offline   Reply With Quote
airy wave, scale, table, time-varying bc "scale"
bash script for pseudo-parallel usage of reconstructPar kwardle OpenFOAM Post-Processing 42 May 8, 2024 00:17
[Other] Contribution a new utility: refine wall layer mesh based on yPlus field lakeat OpenFOAM Community Contributions 58 December 23, 2021 03:36
AMI speed performance danny123 OpenFOAM 21 October 24, 2020 05:13
Extrusion with OpenFoam problem No. Iterations 0 Lord Kelvin OpenFOAM Running, Solving & CFD 8 March 28, 2016 12:08
mixerVesselAMI2D's mass is not balancing sharonyue OpenFOAM Running, Solving & CFD 6 June 10, 2013 10:34
