k and omega values for 2D input simpleFoam
Like Tree1Likes
  • 1 Post By kandelabr
Old   July 18, 2018, 05:37
Default k and omega values for 2D input simpleFoam
Alberto Rinaldi
rinaldialberto is on a distinguished road
Hi there,
I am approaching to run a 2D simulation of a profile. I initialize the flow with simpleFoam and then use steady-state fields as initialization for pimpleFoam.
My question is how to calculate k and omega at inlet for simpleFoam.
Experimental data are:
  • Airspeed U=13.33 m/s
    Turbulence intensity I= 0,003
    Wind tunnel sizes Lx=4m, Ly= 4m (hydraulic diameter dh=4m)
Should I use the values as for a 3D simulation?
k=3/2*(U*I)^2= 0.00239
omega=sqrt(k)/L=sqrt(k)/(0.038*dh)=0.32
do these values make sense for a 2D simulation?
Thanks
Alberto
rinaldialberto is offline   Reply With Quote
Old   August 2, 2018, 03:47
kandelabr's Avatar
Nejc
kandelabr is on a distinguished road
The numbers are the same for 2D and 3D cases:
https://cfd.direct/openfoam/user-guide/v6-cavity/
OpenFOAM always operates in a 3 dimensional Cartesian coordinate system and all geometries are generated in 3 dimensions. OpenFOAM solves the case in 3 dimensions by default but can be instructed to solve in 2 dimensions by specifying a ‘special’ empty boundary condition on boundaries normal to the (3rd) dimension for which no solution is required.
Instead of manually calculating values, I use boundary conditions:
  • turbulentMixingLengthDissipationRateInlet for omega
  • turbulentIntensityKineticEnergyInlet for k
belier1988 likes this.
kandelabr is offline   Reply With Quote
2d simulation, inlet boundary condition, k-omega sst, simple foam, turbulence model
overshooting of Omega in SST komega using simpleFoam cm_jubayer OpenFOAM 2 June 7, 2020 13:52
Airfoil with simpleFoam and kOmegaSST: high drag values? Tsiolkovsky OpenFOAM Running, Solving & CFD 6 November 21, 2018 06:56
oscillatingRotatingMotion: simulation time change with omega and amplitude values decibelle OpenFOAM Running, Solving & CFD 3 November 14, 2018 07:28
SimpleFoam - ramp up values to achieve convergence AmRo OpenFOAM Running, Solving & CFD 0 July 7, 2016 10:38
SimpleFoam converges to wrong values eruwaedhiel OpenFOAM Running, Solving & CFD 3 July 1, 2015 04:01
