Which Pressure BC Compatible with Advective Velocity BC?
Like Tree2Likes
  • 2 Post By syavash
Old   March 2, 2018, 08:09
Default Which Pressure BC Compatible with Advective Velocity BC?
Canakkale Dardanelspor
HakikiCanakkaleli is on a distinguished road
I use advective boundary condition for velocity outlet in an incompressible large eddy simulation. I confused myself for which type of boundary condition I must use to ensure outflow pressure condition is compatible with the advective velocity condition? Currently, the pressure condition is fixedValue.
Kind regards
PS: A similar question seems to be asked here.
HakikiCanakkaleli is offline   Reply With Quote
Old   March 4, 2018, 06:00
Ehsan Asgari
syavash is on a distinguished road
Originally Posted by HakikiCanakkaleli View Post
Kind regards
I use the same combinaion and I think it's typical.
Regards,
Syavash
syavash is offline   Reply With Quote
Old   March 4, 2018, 07:43
I think this pairing can numerically be viable; however, in physical sense, seems incorrect to me. Because, for a spatiotemporally variant velocity field at the outlet, we force gauge pressure to zero, which shouldn't be the case as we let the velocity field out as is by using advective BC. I would prefer to use zeroGradient pressure, yet this is not possible for incompressible applications.
Thanks for your reply,
Old   March 4, 2018, 08:01
Ehsan Asgari
You're welcome. I see your point and I suppose it is true either in case of zeroGradient for velocity at the outlet (instead of advective). However, I have seen a case of boundary-layer simulation which has used zeroGradient for pressure at the outlet. I can provide the link if you wish, but I remember the top boundary was specified as fixedValue for pressure which seems correct to me.
Regards,
Syavash
Old   March 4, 2018, 09:21
I would be glad if you could provide me the link, if possible.
Kind regards,
Old   March 4, 2018, 09:35
Ehsan Asgari
Kind regards,
Sure. This is the link, please let me know if you had any specific opinion after reading it.
https://www.google.ca/url?q=https://...hd2FHcoKcvUlrw
Regards,
Syavash
Old   November 21, 2019, 00:01
Jianrui Zeng
calf.Z is on a distinguished road
I am also using advective BC for velocity and fixedValue for pressure, is it the correct group of settings?
I have found that there is an increase in velocity around the outlet, but I have no idea about it.
calf.Z is offline   Reply With Quote
advective bc, large eddy simulation
No flow rate in outlet with advective velocity rcastilla OpenFOAM Running, Solving & CFD 0 July 19, 2017 05:34
Pressure problems with inlet variable velocity jaimesdiegop CFX 2 September 1, 2016 03:31
Initial pressure and transverse velocity fields to initialize turbulence model nickvinn Main CFD Forum 0 February 29, 2012 11:11
How to set pressure BC with mass Velocity Magnitud arwang FLUENT 2 March 12, 2007 21:04
what the result is negatif pressure at inlet chong chee nan FLUENT 0 December 29, 2001 06:13
