Dimensions in ScalarTransportFoam
Like Tree1Likes
  • 1 Post By Traction
Old   November 26, 2017, 10:15
Default Dimensions in ScalarTransportFoam
Dan
Gesetzt is on a distinguished road
I have an simple question. I'm referring to OF 4.1.
There is the definition of the equation:
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
- fvm::laplacian(DT, T)
fvOptions(T)
So, this means: \frac{\partial T}{\partial t} +\nabla\cdot{(\phi T)}-\nabla(\Gamma \nabla T)=0.
For incompressible fluids phi means: U \cdot A. I don't get the dimensions right here. For the first term it's obviously \frac{K}{s}. But for the second term phi has to be U, to get the right dimension.
I looked up phi and it says: surfaceScalarField phi
IOobject
"phi",
runTime.timeName(),
mesh,
IOobject::READ_IF_PRESENT,
IOobject::AUTO_WRITE
fvc::flux(U)
So what exactly is meant with flux(U), is this without the area? I couldn't find the code definition of flux(U).
I hope someone can help me to clarify this topic.
Best regards
Gesetzt
Gesetzt is offline   Reply With Quote
Old   November 27, 2017, 04:55
Traction is on a distinguished road
please have a look at src/finiteVolume/finiteVolume/fvc/fvcFlux.C where the volVectorField is U in your case! Makes things clearer ?
Gesetzt likes this.
Traction is offline   Reply With Quote
Old   December 3, 2017, 06:48
Dan
Hey,
Thanks. I think it's clear now. Part of the problem was, that I didn't thought about the fact we are using FVM, so for the discretisation over all faces we need the area.
Best Regards,
Gesetzt
Old   February 16, 2018, 03:27
Ramana
svramana is on a distinguished road
fvScalarMatrix TEqn
fvm::ddt(T)
+ fvm::div(phi, T)
fvOptions(T)
IOobject
"phi",
runTime.timeName(),
mesh,
fvc::flux(U)
Best regards
Gesetzt
HI,
i have question about TEqn. can this be valid for porous simple foam also.
svramana is offline   Reply With Quote
scalartransportfoam
Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [0 4 -3 0 0 0 0] mohakbl111 OpenFOAM Running, Solving & CFD 5 February 6, 2019 06:37
FOAM FATAL ERROR for Different dimensions rupesh_w OpenFOAM Running, Solving & CFD 2 April 27, 2016 05:14
Incompatible dimensions for operation ruben23 OpenFOAM Running, Solving & CFD 2 June 12, 2015 05:14
Software that can stretch the overall dimensions of a mesh. Robert_B Main CFD Forum 2 January 27, 2012 08:39
Units in scalartransportfoam Frithjof OpenFOAM 1 January 5, 2011 11:41
