How to rotate a STL file with a fixed point by using surfaceTransformPoints |
November 23, 2017, 04:11 |
Lewis
Rep Power: 10 |
Currently, I build up a horizontal cylinder with the STL file as shown in the attached figure. The cylinder is placed in the XY plane and perpendicular to X- axis. Then, I try to rotate the cylinder to a position (90 degree) which is same as the red line with its central point A. I have tried to type these codes from some online tutorial about the surfaceTransformPoints command:
export FILE="cylinder_v2.stl" #surfaceTransformPoints -yawPitchRoll "(0 90 0)" cylinder.stl $FILE #surfaceTransformPoints -rollPitchYaw "(0 90 0)" cylinder.stl $FILE #surfaceTransformPoints -rotate '( (1 0 0) (0 0 1) )' cylinder.stl $FILE #surfaceTransformPoints -scale '(1 1 -1)' cylinder.stl $FILE Thanks in advance! Zuodong |
January 4, 2018, 11:37 |
#2 | |
Mark Olesen
Rep Power: 40 |
Eg '-scale 0.001' instead of -scale '(0.001 0.001 0.001)' for less typing and fewer mistakes. |
January 7, 2018, 01:24 |
#3 | |
Lewis
Rep Power: 10 |
Cheers! Zuodong |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] problem when installing foam-extend-1.6 | Thomas pan | OpenFOAM Installation | 7 | September 9, 2015 21:53 |
Trouble compiling utilities using source-built OpenFOAM | Artur | OpenFOAM Programming & Development | 14 | October 29, 2013 10:59 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
OpenFOAM on MinGW crosscompiler hosted on Linux | allenzhao | OpenFOAM Installation | 127 | January 30, 2009 19:08 |
