blockMesh - two blocks with different vertices
Like Tree2Likes
  • 2 Post By Antimony
Old   October 7, 2017, 11:03
Default blockMesh - two blocks with different vertices
Ruggiero Guida
Rojj is on a distinguished road
Hello
Is it possible to create a Mesh made by two blocks with different vertices and then use snappyHexMesh?
I have created the following mesh
// -*- C++ -*-
// File generated by PyFoam - sorry for the ugliness
FoamFile
 version 2.0;
 format ascii;
 class dictionary;
 object blockMeshDict;
convertToMeters 1;
vertices
    (-595.82 -620.459 -5)
    (670.098 -620.459 -5)
    (670.098 645.459 -5)
    (-595.82 645.459 -5)
    (-595.82 -620.459 100)
    (670.098 -620.459 100)
    (670.098 645.459 100)
    (-595.82 645.459 100)
    (-595.82 -620.459 520)
    (670.098 -620.459 520)
    (670.098 645.459 520)
    (-595.82 645.459 520)
  blocks
      hex (0 1 2 3 4 5 6 7) (158 158 10) simpleGrading (1 1 1)
      hex (8 9 10 11 12 13 14 15) (79 69 28) simpleGrading (1 1 1)
  edges
  boundary
      sides
        type patch;
        faces (
                (0 4 7 3)
                (8 12 15 11)
                (6 5 1 2)
                (14 13 9 10)
      inlet
        type patch;
        faces (
                (3 7 6 2)
                (11 15 14 10)
      outlet
        type patch;
        faces (
                (5 4 0 1)
                (13 12 8 9)
      ground
        type wall;
        faces (
                (3 2 1 0)
      internalBottom
        type patch;
        faces (
                (4 5 6 7)
      internalTop
        type patch;
        faces (
                (8 11 10 9)
      sky
        type patch;
        faces (
                (12 13 14 15)
    mergePatchPairs (
      ( internalTop internalBottom ) );
but when I mesh with snappyHexMesh I receive the following error
Selected for refinement : 44456 cells (out of 404984)
hexRef8 : Dumping cell as obj to "/home/ubuntu/OpenFOAM/ubuntu-4.1/run/test02_base_Baseline/mesh/cell_251301.obj"
--> FOAM FATAL ERROR:
cell 251301 of level 0 uses more than 8 points of equal or lower level
Points so far:8(254492 254493 254572 254573 260092 260093 260172 260173)
    From function Foam::labelListList Foam::hexRef8::setRefinement(const labelList&, Foam::polyTopoChange&)
    in file polyTopoChange/polyTopoChange/hexRef8/hexRef8.C at line 3701.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::hexRef8::setRefinement(Foam::List<int> const&, Foam::polyTopoChange&) at ??:?
#3  Foam::meshRefinement::refine(Foam::List<int> const&) at ??:?
#4  Foam::meshRefinement::refineAndBalance(Foam::string const&, Foam::decompositionMethod&, Foam::fvMeshDistribute&, Foam::List<int> const&, double) at ??:?
#5  Foam::snappyRefineDriver::surfaceOnlyRefine(Foam::refinementParameters const&, int) at ??:?
#6  Foam::snappyRefineDriver::doRefine(Foam::dictionary const&, Foam::refinementParameters const&, Foam::snapParameters const&, bool, Foam::dictionary const&) at ??:?
#7  ? at ??:?
#8  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9  ? at ??:?
Aborted (core dumped)
Cell 251301 is located at the interface internalTop/internalBottom.
I have tried to change slave and master, but the problem just happens in a different cell.
this picture shows the mesh and this one shows the cell
Rojj is offline   Reply With Quote
Old   October 8, 2017, 23:42
Antimony is on a distinguished road
Nope. To the best of my knowledge, with snappyHexMesh you cannot do that. While blockMesh might merge the two meshes that you created, the resultant mesh is no longer purely hexahedral, which is a requirement to be able to run snappyHexMesh.
Instead you can do the following (assuming your geometry that you want to run your snappy on is less than the height of your first block):
1. Have a case and in that run blockMesh with only the first block
2. For the case from step 1, run snappyHexMesh
3. Have a separate case and in that run blockMesh with only the second block
4. Merge the two cases together using mergeMesh
5. Use either stitchMesh or cyclicAMI to take care of the overlapping patches.
Hope this helps.
Cheers,
Antimony
Rojj and farzadmech like this.
Antimony is offline   Reply With Quote
Old   October 13, 2017, 05:54
Ruggiero Guida
Thanks Antimony. That certainly clarifies the issue.
Your proposed solution is interesting. As I am running everything programmatically, it might be relatively simple to implement.
I am now testing the cyclicAMI. I would like to better understand how it works (I will probably need it in the near future) and see if I can avoid the two step meshing.
Will report back.
Old   March 21, 2023, 21:39
Farzad Faraji
farzadmech is on a distinguished road
Dear Antimony,
Thanks a lot for your suggestion. I am going to use it for my case to avoid huge cell numbers. I already posted my problem, I will be happy if you look at it.
Thanks,
Farzad
Originally Posted by Antimony View Post
Hope this helps.
Cheers,
Antimony
farzadmech is offline   Reply With Quote
blockmesh, snappyhexmesh
[Commercial meshers] COnvert FLuent MEsh to openfoam with interface manuc OpenFOAM Meshing & Mesh Conversion 1 July 25, 2017 04:13
[Commercial meshers] converting Fluent mesh to openfoam standard mesh deepesh OpenFOAM Meshing & Mesh Conversion 31 March 29, 2017 06:59
dsmcInitialise - dsmcFoam archymedes OpenFOAM Pre-Processing 94 July 15, 2016 17:14
[blockMesh] blockMesh - numbering of vertices with multiple blocks AmRo OpenFOAM Meshing & Mesh Conversion 6 May 16, 2016 06:05
[blockMesh] blockMesh problem with blocks with vertices adrieno OpenFOAM Meshing & Mesh Conversion 3 March 23, 2016 04:35
