October 1, 2017, 06:15 |
Problem with blockMesh
Chen Sihe
Rep Power: 9 |
Hi guys
I have written a blockMesh file and the error continuously comes out: Code:
--> FOAM FATAL IO ERROR: "ill defined primitiveEntry starting at keyword 'boundary' on line 55 and ending at line 125" file: /home/francisco/Escritorio/horno/constant/polyMesh/blockMeshDict at line 125. From function primitiveEntry::readEntry(const dictionary&, Istream&) in file lnInclude/IOerror.C at line 132. FOAM exiting Can anyone help to have a look at the error here? Thanks a lot! Code:
/*--------------------------------*- C++ -*----------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.4.0 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // convertToMeters 0.001; vertices ( (149.857 -6.543 0) (149.857 -6.543 450) (74.929 -3.271 450) (74.929 -3.271 0) (149.857 6.543 0) (149.857 6.543 450) (74.929 3.271 450) (74.929 3.271 0) (9.990 -0.436 0) (9.990 -0.436 450) (0 0 450) (0 0 0) (9.990 0.436 0) (9.990 0.436 450) ); blocks ( hex (0 1 2 3 4 5 6 7) (12 1 35) simpleGrading (1 1 1) hex (3 2 9 8 7 6 13 12) (18 1 70) simpleGrading (1 1 1) hex (8 9 10 11 12 13 10 11) (23 1 1000) simpleGrading (1 1 1) ); edges ( arc 3 7 (75 0 0) arc 2 6 (75 0 450) arc 8 12 (10 0 0) arc 9 13 (10 0 450) arc 0 4 (150 0 0) arc 1 5 (150 0 450) ); boundary ( inletAnnular { type patch; faces ( (7 4 0 3) ); } inletCentral { type patch; faces ( (8 11 11 12) ); } outlet { type patch; faces ( (1 5 6 2) (2 6 13 9) (9 13 10 10) ); } bottom { type symmetryPlane; faces ( (0 1 2 3) (3 2 9 8) (8 9 10 11) ); } top { type symmetryPlane; faces ( (4 5 6 7) (7 6 13 12) (12 13 10 11) ); } bluffBody { type wall; faces ( (2 6 13 9) (7 3 8 12) ); } centerLine { type empty; faces ( (10 11 11 10) ); } ); mergePatchPairs ( ); // ************************************************************************* // |
October 2, 2017, 05:41 |
Hrvoje Jasak
Rep Power: 33 |
You probably had a stray invisible character somewhere in the text file. Delete blockMeshDict, make a new one and do a copy-paste from the above. blockMesh runs for me, but you still have problems with the mesh (not surprising): Code:
temple*9-> blockMesh /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | foam-extend: Open Source CFD | | \\ / O peration | Version: 4.0 | | \\ / A nd | Web: http://www.foam-extend.org | | \\/ M anipulation | For copyright notice see file Copyright | \*---------------------------------------------------------------------------*/ Build : 4.0-f0c05c478cb3 Exec : blockMesh Date : Oct 02 2017 Time : 10:39:11 Host : temple PID : 14516 CtrlDict : "/home/hjasak/foam/hjasak-4.0/run/support/test/system/controlDict" Case : /home/hjasak/foam/hjasak-4.0/run/support/test nProcs : 1 SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). SetNaN : Initialising allocated memory to NaN (FOAM_SETNAN). // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Creating block mesh from "/home/hjasak/foam/hjasak-4.0/run/support/test/constant/polyMesh/blockMeshDict" Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -55150.8 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -55150.8 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -73538.1 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -36763.4 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -55150.8 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -55150.8 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 202 negative volume block : 0, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -18054.7 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -18054.7 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -31862.3 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -4247.01 for face 3 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -18054.7 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -18054.7 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 202 negative volume block : 1, probably defined inside-out --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -326.673 for face 0 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -326.673 for face 1 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -653.346 for face 2 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -326.673 for face 4 --> FOAM Warning : From function cellModel::mag(const labelList&, const pointField&) in file meshes/meshShapes/cellModel/cellModel.C at line 128 zero or negative pyramid volume: -326.673 for face 5 --> FOAM Warning : From function blockMesh::createTopology(IOdictionary&) in file blockMesh/blockMeshTopology.C at line 202 negative volume block : 2, probably defined inside-out --> FOAM FATAL ERROR: Trying to specify a boundary face 4(2 6 13 9) on the face on cell 1 which is either an internal face or already belongs to some other patch. This is face 0 of patch 5 named bluffBody. From function polyMesh::setTopology ( const cellShapeList& cellsAsShapes, const faceListList& boundaryFaces, const wordList& boundaryPatchNames, labelList& patchSizes, labelList& patchStarts, label& defaultPatchStart, label& nFaces, cellList& cells ) in file meshes/polyMesh/polyMeshFromShapeMesh.C at line 357. FOAM aborting (FOAM_ABORT set) #0 Foam::error::printStack(Foam::Ostream&) at ~/foam/foam-extend-4.0/src/OSspecific/POSIX/printStack.C:238 #1 Foam::error::abort() at ~/foam/foam-extend-4.0/src/foam/lnInclude/error.C:225 #2 Foam::Ostream& Foam::operator<< <Foam::error>(Foam::Ostream&, Foam::errorManip<Foam::error>) at ~/foam/foam-extend-4.0/src/foam/lnInclude/errorManip.H:86 (discriminator 4) #3 Foam::polyMesh::setTopology(Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::List<int>&, Foam::List<int>&, int&, int&, Foam::List<Foam::cell>&) at ~/foam/foam-extend-4.0/src/foam/meshes/polyMesh/polyMeshFromShapeMesh.C:364 (discriminator 3) #4 Foam::polyMesh::polyMesh(Foam::IOobject const&, Foam::Xfer<Foam::Field<Foam::Vector<double> > > const&, Foam::List<Foam::cellShape> const&, Foam::List<Foam::List<Foam::face> > const&, Foam::List<Foam::word> const&, Foam::PtrList<Foam::dictionary> const&, Foam::word const&, Foam::word const&, bool) at ~/foam/foam-extend-4.0/src/foam/meshes/polyMesh/polyMeshFromShapeMesh.C:868 #5 Foam::blockMesh::createTopology(Foam::IOdictionary const&, Foam::word const&) at ~/foam/foam-extend-4.0/src/mesh/blockMesh/blockMesh/blockMeshTopology.C:546 (discriminator 4) #6 Foam::blockMesh::blockMesh(Foam::IOdictionary const&, Foam::word const&) at ~/foam/foam-extend-4.0/src/mesh/blockMesh/blockMesh/blockMesh.C:39 (discriminator 2) #7 at ~/foam/foam-extend-4.0/applications/utilities/mesh/generation/blockMesh/blockMeshApp.C:159 #8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #9 at ??:? Abort
Hrvoje Jasak Providing commercial FOAM/OpenFOAM and CFD Consulting: http://wikki.co.uk |
October 2, 2017, 11:46 |
#3 | |
Chen Sihe
Rep Power: 9 |
Sent from my Redmi 4X using CFD Online Forum mobile app |
blockmesh, blockmeshdict, openfoam3.0.1 |
[snappyHexMesh] Problem and doubts with blockMesh, snappyHexMesh and multiple geometry | luca1992 | OpenFOAM Meshing & Mesh Conversion | 0 | August 23, 2017 11:40 |
[blockMesh] BlockMesh problem | ari92 | OpenFOAM Meshing & Mesh Conversion | 2 | May 27, 2017 10:23 |
[blockMesh] blockMesh problem with wedge blocks | gned | OpenFOAM Meshing & Mesh Conversion | 0 | September 14, 2016 05:49 |
[blockMesh] Problem with blockMesh and my shape | TneurolF | OpenFOAM Meshing & Mesh Conversion | 4 | June 25, 2013 13:52 |
Blockmesh problem with more than one block | sven82 | OpenFOAM Pre-Processing | 1 | June 4, 2013 17:08 |
