How to make venting? Is it possible?
Like Tree3Likes
  • 1 Post By elvis
  • 2 Post By krikre
Old   September 5, 2017, 18:19
Lightbulb How to make venting? Is it possible?
KlemenFr.
Klemen is on a distinguished road
Hello Foamers!
I have a modified interFoam solver with which am trying to simulate injection molding. Cavity does not have any outlet and inside of it is initially air.
While filling this cavity with fluid(polymer), air should go out but not polymer.
What should I do? How to make the polymer fill the cavity and vent the air out without specifying an outlet?
In reality, air leaves the cavity on many places, but it's flow is not important.
For any answer I will be very thankful!
Kind Regards,
Klemen
Klemen is offline   Reply With Quote
Old   September 17, 2017, 11:59
Elvis
elvis will become famous soon enough
https://www.cfd-online.com/Forums/op...-openfoam.html
Boundary conditions when simulating injection molding
Polymer processing injection molding application
Klemen likes this.
elvis is offline   Reply With Quote
Old   October 1, 2017, 11:39
Kristjan
krikre is on a distinguished road
The boundary condition outletPhaseMeanVelocityFvPatchVectorField is almost the solution to this problem. It's derived from the mixed boundary condition, so it switches between the zero gradient and zero value based on the alpha field.
This needs to be done for both the velocity and pressure fields. I made the modifications and it seemed to work for a while but then divergence occurred which I didn't have the time and knowledge to resolve. I might post an update if I get it to work properly in which case I'll provide an example case. Until then the code will be on a temporary branch 'bcLibTemporary' in my repo.
Klemen and JuRe09 like this.
krikre is offline   Reply With Quote
Old   September 4, 2020, 03:21
Samuele Z
samiam1000 is on a distinguished road
Hi Klemen,
I am working on a similar problem. Do you have any update, by chance?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   June 21, 2022, 15:24
Julian Re
JuRe09 is on a distinguished road
Hey Samuele,
did you solved the challenge with the venting BC? Could realy need some guidance on this topic...
JuRe09 is offline   Reply With Quote
injection molding, open foam, venting
[waves2Foam] Waves2Foam Related Topics ngj OpenFOAM Community Contributions 660 August 20, 2018 13:39
how can make normal shock in the nozzle at inlet B.C : Pressure Far field SonicGhoul FLUENT 2 May 8, 2016 06:16
error make SU2 4.0.1 Heathckliff SU2 Installation 2 November 9, 2015 06:48
how to make a series of plane with equidistance in postprossing of result sunxihui FLUENT 0 January 13, 2013 10:50
[Q]How to make MPEGs with CFD datas??? Bum-Seok Hyun Main CFD Forum 4 February 16, 2000 19:59
