how to add a turbulence into a laminar model? |
Matthew
Rep Power: 9 ![]() |
Hi, I have done a simple model of using a velocity at the inlet, to achieve a laminar flow passing through a pipe. The solver is icoFoam. Now I would like to change to a turbulent flow without using any turbulence model (actually I would like to do the DNS). How to modify the boundary conditions to achieve a turbulence?
ano
Rep Power: 10 ![]() |
Hi Matthew,
to turn laminar flow turbulent you have to give some noise as initial condition. To maintain a turbulent flow in a pipe you have to use periodic boundary conditions (and a function object, which imposes a pressure gradient onto your pipe, so that the mean flow rate is steady).
Jianrui Zeng
Rep Power: 8 ![]() |
Hello Matthew,
Have you resolved your problem?I am doing similar research on DNS of heated pipe flow. Any hint or guide is appreciated. Thank you. |
Turbulence model under laminar conditions | mbranag | CFX | 12 | March 13, 2023 20:06 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Capture Laminar Separation Bubble with K-Kl Turbulence Model | alireza_b | FLUENT | 0 | April 14, 2014 13:16 |
Aerofoil Modelling - Laminar approximation, transition and turbulence modelling. | Asatorae | STAR-CCM+ | 1 | January 20, 2014 05:25 |
Why Turbulence models are not universal. | Senthil | Main CFD Forum | 4 | July 5, 2000 04:34 |
