Restrict/Convert velocity inlet from entire bottom surface to the bottom center
Like Tree2Likes
  • 1 Post By nimasam
  • 1 Post By ronithstanly
Old   August 25, 2017, 13:26
Default Restrict/Convert velocity inlet from entire bottom surface to the bottom center
Ronith Stanly
ronithstanly is on a distinguished road
I am using the domain of the dpmfoam test case- Goldschmidt.
In the default test case the velocity inlet is from the entire bottom surface of the cuboidal domain, but I would like to restrict the velocity inlet to be just from the center of the bottom surface (like a jet of air from the bottom center).
How will I proceed with changing the boundary condition? Please help.
ronithstanly is offline   Reply With Quote
Old   August 27, 2017, 03:17
Nima Samkhaniani
nimasam is on a distinguished road
two options available:
1- change the inlet in your grid
2-using groovyBC
However the option one is more accurate
ronithstanly likes this.
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   August 30, 2017, 03:39
Talking
Ronith Stanly
Dear Mr.Nima Samkhaniani,
Thank you so much for your suggestion. I changed the grid and it worked perfectly!
I converted the grid into 3 hex blocks (one central block with the rectangular bottom jet and the two other blocks on its either sides) and it got merged by face matching.
I have attached the screenshot
Thanking You,
Ronith Stanly
nimasam likes this.
Old   September 4, 2017, 07:03
Default Particle Volume Fraction
Ronith Stanly
Can you please let me know how to view the solid volume fraction in paraview? I am only able to see the volume fraction of air- I want the particles to be coloured based on the volume fraction, like the attached image (from literature). Please help.
File Type: png Screenshot from 2017-09-04 16-56-14--1.png (59.1 KB, 7 views)
Old   September 4, 2017, 11:18
Nima Samkhaniani
use paraview calculator, solid volume fraction would be:
solidVolumeFraction = 1.0 - airVolumeFraction;
boundary condition, dpmfoam, inlet bc, openfoam
inlet velocity in free surface in CFX yaseen wsu CFX 1 March 30, 2016 08:01
Problem with assigned inlet velocity profile as a boundary condition Ozgur_ FLUENT 5 August 25, 2015 05:58
Velocity inlet boundary condition for porous medium Chander CFX 3 March 11, 2012 22:18
Neumann pressure BC and velocity field Antech Main CFD Forum 0 April 25, 2006 03:15
UDF paraboloid velocity inlet Ronak Shah FLUENT 0 June 4, 2003 10:44
