motorbike tutorial
Like Tree1Likes
  • 1 Post By Jam Racing 2015
Old   June 21, 2017, 05:41
Default motorbike tutorial
Jam Racing 2015's Avatar
john mcgeorge
Jam Racing 2015 is on a distinguished road
Hello.Need help.I want to put an S.T.L file of my Formula Vee racing car in place of motorbike.Do I need to change size of wind tunnel,reynolds number??I have read on an F1 forum and someone there says garbage in garbage out.How accurate will my results be.Forces,streamlines and cutting plane.Thanks John
Jam Racing 2015 is offline   Reply With Quote
Old   June 21, 2017, 08:39
Default Terrible
john mcgeorge
Why wud my post be terrible.I am asking question that I do not the answer to frm u experts and get rated TERRIBLE???? What is the purpose of this forum then
Old   June 21, 2017, 12:24
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
John,
Pay no attention to the rating, I was not aware that one could rate these posts ... plus, your question isn't terrible. So no worries
Now, to answer or provide some guidance. To mesh your car it is a little more than just replacing your STL in the motorbike tutorial. You will need to think about a few things:
  1. What are the physical dimensions of you car? --> this influences the size of the wake boxes and placement around the vehicle
  2. How big is your wind tunnel? --> you will need to change the blockMeshDict or add a wind tunnel stl.
  3. What is the smallest feature you want to capture on your car? --> this will influence the selection of base mesh size and also local refinement level
  4. Is the floor stationary or moving? --> this will influence boudnary conditions or if you need something else like a slip to no-slip boundary on the floor
You will need to edit the system/snappyHexMesh and add entries for the new geometry, edit surface (and volume) refinements, change any size of the wake boxes, configure layer controls and most likely the locationInMesh entry. For vehicles, these meshes can become really large (in fact the motorbike isn't detailed enough for analysis) so think about your computing resources available. To get a nice match with experimental results on a detailed vehicle, we are talking about 10's of millions of cells. My colleague gave a brief introduction to snappyHexMesh (search for snappyHexMesh) at the last OpenFOAM workshop (there are others from previous workshops too). Good luck and just ignore the ratings
chegdan is offline   Reply With Quote
Old   June 21, 2017, 13:09
john mcgeorge
First of all u are an Officer and a Gentleman.U too the time to answer my question.What I was trying to get at is if I put my s.t.l file in of my racing car without change any settings,the results wud not be correct.So the guy on the F1 forum was correct in saying that if u do not know how to set up OpenFoam,ur results will not be accurate.
chegdan likes this.
Old   June 21, 2017, 13:19
Daniel P. Combest
No problem! I'd definitely agree with the F1 Forum comment and your earlier comment of "Garbage in, garbage out". These simulations take some time to wrap your head around, but you start with deciding what you want to achieve and then go from there. Ask away.
Old   June 21, 2017, 13:30
john mcgeorge
I did the drawing of car in Rhino cad.I did not know how to round off edges as on real car.But the streamlines show a problem at front suspension which is off a Beetle.Two 50 mm pipes.I see the flow seperates big time behind them.That was my area of concern.I do not know how to have wheels rotating either.They wud have a huge effect on the aero around body too.So moral of this is C.F.D is not childs play.Have built a small wind tunnel and my test around a model of my car show similar flow past front suspension when smoke added.I am not doing this for gain but rather as a hobby.
Old   June 21, 2017, 14:26
Daniel P. Combest
This sounds like a pretty fantastic hobby.
You may want to look at some OpenFOAM material on Automotive Simulation like this one i found. For rotating wheels, you can set a rotational boundary condition with something like a rotatingWallVelocity (How to use rotatingWallVelocity boundary condition).
Old   June 21, 2017, 15:06
john mcgeorge
Thanks.Was reading up on our friend snappy. So much to learn.Ur help is appreciated
Sent from my Chacer using CFD Online Forum mobile app
Old   June 21, 2017, 15:10
john mcgeorge
Do the wheels have to separate from model?
Inside of the motorbike tutorial meth OpenFOAM 0 March 20, 2017 02:06
Motorbike tutorial for snappyhexmesh taking forever to run? massive_turbulence OpenFOAM Running, Solving & CFD 0 April 27, 2014 03:00
[snappyHexMesh] Tweaked motorbike tutorial doesn't show my icosphere mfiandor OpenFOAM Meshing & Mesh Conversion 0 October 9, 2011 19:39
Wrong file in motorBike tutorial? lovecraft22 OpenFOAM 3 August 4, 2011 14:03
ensightToFoam error with motorBike tutorial az_monger OpenFOAM 2 August 17, 2009 15:45
