Periodic Boundary Condition
Like Tree23Likes
  • 11 Post By fatirishman53
  • 2 Post By agustinvo
  • 4 Post By fatirishman53
  • 3 Post By agustinvo
  • 3 Post By FlyBob91
Old   March 25, 2017, 05:24
Question Periodic Boundary Condition
FlyBob91's Avatar
FlyBob91 is on a distinguished road
Hello to all,
In many papers, to simulate a fully developed flow in a geometry (pipe or channel), i've seen is practice, to avoid modelling a long pipe, to implement periodic boundary condition at the inlet and outlet.
Can someone explain me how to implement this method?
Thanks for help
FlyBob91 is offline   Reply With Quote
Old   March 25, 2017, 15:35
Matt
fatirishman53 is on a distinguished road
Originally Posted by FlyBob91 View Post
Hello to all,
Thanks for help
Your boundaries would be defined using (i.e. in blockMeshDict):
inlet
    type              cyclic;
    neighbourPatch    outlet;
    faces             ((0 1 2 3));  // insert your particular vertex numbers
outlet
    type              cyclic;
    neighbourPatch    inlet;
    faces             ((4 5 6 7));  // insert your particlular vertex numbers
Then in your U, p, etc. files you would define, under boundaryField:
inlet
    type                      cyclic;
outlet
    type                      cyclic;
fatirishman53 is offline   Reply With Quote
Old   March 27, 2017, 05:28
FlyBob91's Avatar
Hello IrishMan, thanks for your fast reply and sorry for my late one.
I have a doubt, how can i define an initial velocty at the inlet with a cyclic BC?
Many thanks
Old   March 27, 2017, 05:45
Agustín Villa
agustinvo is on a distinguished road
Hello
what I would do to initialize your velocity, is to change the internalField value.
FlyBob91 and sabrinacarson like this.
agustinvo is offline   Reply With Quote
Old   March 27, 2017, 22:21
Matt
Many thanks
As agustinov pointed out, you could set your internal mesh to a uniform velocity. You could also use something like swak4foam to create a particular velocity profile. However, you also need something to keep your flow moving. The meanVelocityForce fvOption (OpenFOAM-3.0.x) introduces a force term to the NS equations in order to maintain a user-defined bulk velocity.
utkunun, FlyBob91, SHANRU and 1 others like this.
Old   March 30, 2017, 14:53
FlyBob91's Avatar
Thanks guys for your replies.
I made all you said me but unfortunately after launching pimpleFoam this error occurs
--> FOAM FATAL IO ERROR:
Unable to set reference cell for field p
    Please supply either pRefCell or pRefPoint
file: /home/roby/Scrivania/Auxiliary/system/fvSolution.PIMPLE from line 57 to line 58.
    From function void Foam::setRefCell
    const volScalarField&,
    const dictionary&,
    label& scalar&,
    bool
    in file cfdTools/general/findRefCell/findRefCell.C at line 125.
here my U,p and blockMesh file
U
dimensions      [ 0 1 -1 0 0 0 0 ];
internalField   uniform (0 0.42 0);
boundaryField
    inlet
        type            cyclic;
    walls
        type            fixedValue;
        value           uniform (0 0 0);
    outlet
        type            cyclic;
P
dimensions      [ 0 2 -2 0 0 0 0 ];
internalField   uniform 0;
boundaryField
    inlet
        type            cyclic;
    walls
        type            zeroGradient;
    outlet
        type            cyclic;
blocjMeshDict
boundary
    walls
        type wall;
        faces
            (3 2 1 0)
	    (0 1 5 4)
            (4 5 6 7)
            (2 3 7 6)
    inlet
        type cyclic;
        faces
            (0 4 7 3)
    outlet
        type cyclic;
        faces
            (1 2 6 5)
Many thanks
Old   March 31, 2017, 07:25
Agustín Villa
Please take a look here. since you are not imposing a pressure value in your BC-s, the solver is asking for it. you have to give it in your fvSolution, as you see from your error, inside the PIMPLE dictionary. In this way, you will have a reference pressure to compute the pressure field.
https://github.com/OpenFOAM/OpenFOAM...tem/fvSolution
Old   May 2, 2017, 10:03
FlyBob91's Avatar
Sorry for the thread bumping but the solutions proposed above seem not to work good for my case, because the flow seems to slow down very quickly respect the value i want to impose at the inlet. This must be because there is no a driving force.
Maybe the problem could be fixed by setting a value of flowrate. The informations i have are the density and the inlet velocity (uniform).
I read some threads about the same problem but no one has given me a completely solution.
Old   May 2, 2017, 10:47
Matt
Old   May 2, 2017, 10:57
FlyBob91's Avatar
Hi fatirishman,
unfortunately i'm on OF 2.3.0 and it seems meanVelocityForce fvOptionis is only for OF 3.0.
Can i use it evenly? And if yes, how?
Many thanks for your help
Old   May 2, 2017, 16:33
Matt
Hi fatirishman,
I can't remember what it is called, but I know OF 2.4.0 had something similar. Just do a google search for OpenFOAM fvOptions.
Old   May 3, 2017, 04:21
Agustín Villa
take a look to this fvOption
https://github.com/OpenFOAM/OpenFOAM...plicitSource.H
or to the boundaryFoam solver
https://github.com/OpenFOAM/OpenFOAM...e/boundaryFoam
With one of them you should reach the setup you are looking for.
Old   May 17, 2017, 06:01
FlyBob91's Avatar
Thank you both guys for your help.
I post the solution for future users
In OpenFOAM 2.3.x the following linked fvOptions file must be put into the system directory. You can also refer to the tutorial in $FOAM_TUTORIALS/incompressible/pimpleFoam/channel395/
I also test it in OpenFoam v-1612+ but the syntax is a bit different and there is no an example to look for, so i link the complete case below
Hope it helps
File Type: gz fvOptions_OpenFOAM230.tar.gz (501 Bytes, 189 views)
agustinvo, randolph and Amit@22 like this.
Old   July 13, 2018, 12:45
Default Periodic Boundary Condition for Temperature
  #14
nahideh
nj@2018 is on a distinguished road
Hello to all,
I read your description about fvOption, it was helpful for velocity and pressure, but how about Temperature, how can I have Periodic Boundary Condition for Temperature field?
Thank you all
nj@2018 is offline   Reply With Quote
Old   July 19, 2018, 06:40
Agustín Villa
Hi
keep a cyclic temperature is simple. You need to know your heat balance, it is, the amount of heat that you introduce (or remove) inside the domain.
Then, set this amount in a similar entry in your fvOptions, where you extract (or add) the same amount of heat. Remember to be coherent with units!
Old   July 23, 2018, 11:18
nahideh
Thank you agustinvo; what you explained seems to be suitable for constant wall heat flux, isn't it?
The problem I have faced is constant wall temperature, a brief description of the problem is like this:
The system considered for the problem, consisted bank of tubes containing a flowing fluid at one temperature that is immersed in a second fluid in cross flow at a different temperature.
and one more thing, is this all based on article of Patankar et al. (1977), “Fully developed flow and heat transfer in ducts having streamwise-periodic variation of cross-sectional area”?
Best Regards
Old   September 28, 2018, 23:12
krishna kant
kk415 is on a distinguished road
Hello All,
I want to solve a vortex stretching problem in which we have a drop at C(0.5,0.75) in a square of unit size. Now the streamline is given as
\psi = (1/\pi)*\cos(\pi*t/T)*\sin^2(\pi*x)*\sin^2(\pi*y)
The problem is that the Boundary Conditions for all variables is periodic for all four patches that surrounds the domain. If we have a inlet and outlet I can define the neighboring patch for inlet as outlet and vice versa. As shown in the examples above. But what if all the patch is periodic, what should be the neighboring patches for top, bottom, left and right.
kk415 is offline   Reply With Quote
Old   November 28, 2018, 08:02
Fraser Monaghan Brash
Brash96 is on a distinguished road
I am new to using OpenFoam and have a problem involving a 3D channel with fluid between 2 flat plates (that are being heated).
I am looking to implement cyclic boundary conditions on the fluid and include a heat sink to subtract the calculated heat flux at each time step to ensure no exponential heating.
I am unsure as to how to do this and any suggestions or advice would be greatly appreciated.
Many thanks,
Fraser
Brash96 is offline   Reply With Quote
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Unsteady Periodic Boundary Condition EMolina SU2 0 July 24, 2014 17:16
About periodic boundary condition. kohel_11 FLUENT 3 July 30, 2013 08:37
Error finding variable "THERMX" sunilpatil CFX 8 April 26, 2013 08:00
