interFoam, nonuniform alpha for channel flow
Like Tree1Likes
  • 1 Post By KTG
Old   February 23, 2017, 23:41
Default interFoam, nonuniform alpha for channel flow
KTG
Abe
KTG is on a distinguished road
Hi Foamers,
I am trying to setup a simple test case for channel flow boundary conditions. I would like to have river-like flow, using the interFoam solver. The attached zip contains a case file, where water is invading a square channel, and displacing air (see screenshot). I have two questions:
1) Is there a simple way to set the value of alpha at the boundary to be noninform in space? For example, alpha=1 for y<=.5, alpha=0 for y>.5. This is just a shifted heavyside function of y, but I can't figure out how to implement it. I will eventually be using these boundary conditions with a more complicated geometry, so my goal is to find a way to implement different water heights without having to re-mesh every time. This seems simple enough that I shouldn't have to write a new boundary condition, but I am lost on the implementation. Its ok if the water height is constant in time.
2) In the attached case, I have set pressure and velocity boundary conditions based on what I have read on the forums for stability reasons. In reality, I have measured the velocity, but not the pressure in a river. Why is it ok to set uniform pressures at the boundaries , and how should I choose the actual values? Also, it seems that things are not stable unless I put a little water against the inlet for the initial value. This is not really a problem, but if someone can explain that behavior, I would be very interested.
Thanks!
ahparvin likes this.
KTG is offline   Reply With Quote
bounday conditions, channel flow, interfoam, pressure
Issues on the simulation of high-speed compressible flow within turbomachinery dowlee OpenFOAM Running, Solving & CFD 11 August 6, 2021 07:40
setting a Constant Inlet flow - Interfoam bdh1103 OpenFOAM Programming & Development 10 March 6, 2016 10:29
Interfoam - Real world Geometry with constant inlet flow bdh1103 OpenFOAM Running, Solving & CFD 0 February 10, 2016 15:54
Open channel flow with interFoam sorockin OpenFOAM Running, Solving & CFD 8 October 20, 2013 07:50
Flow meter Design CD adapco Group Marketing Siemens 3 June 21, 2011 09:33
