buoyantBoussinesqSimpleFoam heat flux boundary condition
Like Tree1Likes
  • 1 Post By agustinvo
Old   February 15, 2017, 21:56
Default buoyantBoussinesqSimpleFoam heat flux boundary condition
Sebastien Brideau
SBrideau is on a distinguished road
Hi all,
I'm a complete beginner with openfoam. I'm trying to place a heat flux boundary condition with the buoyantBoussinesqSimpleFoam solver.
I have openfoam version 4.
There seems to be a compressible boundary condition, but I can't find one for incompressible solvers.
https://github.com/OpenFOAM/OpenFOAM...hScalarField.H
There seemed to have been one in the previous versions of openfoam for incompressible solvers:
Is there something I'm missing? I've searched online, but some of the explanations went way over my head.
SBrideau is offline   Reply With Quote
Old   February 17, 2017, 06:21
Agustín Villa
agustinvo is on a distinguished road
Hello Sebastien,
by default, there is no heat flux BC for incompressible solvers. However, you can try to program it. Start form the compressible one, and then start to change it.
agustinvo is offline   Reply With Quote
Old   February 17, 2017, 10:23
Sebastien Brideau
Hi agustinvo,
Thank you so much for your reply, and for confirming what I thought. Unfortunately, adding to the source code is too complex for me at this time. As I said, I'm just starting, and it is a lot to learn.
Thanks again.
Old   February 17, 2017, 11:16
Agustín Villa
Hi
do not worry, try to use swak4Foam, and use a groovyBC to set a gradient. That gradient you fix it since
q_w = k * gradT
you define your gradient as q_w/k, and you set the values for the heat flux and thermal conductivity. Please take care of the turbulent conductivity as well. If you have a refined mesh, you should not worry a lot about it, but with this it should be enough.
Luttappy likes this.
Old   May 6, 2017, 18:47
Himanshu Sharma
himanshu28 is on a distinguished road
I don't get it when it was available with the previous version what led to the removal of that boundary condition from the latest version OF-4.x.
I am also trying to use heatflux[W/m^2] BC for my problem,which I sucessfully used till OF2.4 but now it seems it's not there.
Any clue if it is avaliable in the development version? I am not sure how to proceed to code it myself hence asking.
Thank you
himanshu28 is offline   Reply With Quote
Old   June 8, 2017, 04:45
JLS
Jaime
JLS is on a distinguished road
Originally Posted by agustinvo View Post
Hi
q_w = k * gradT
Hi Agustin,
I have the same problem as Sebastien, and I guess I will try to create this BC. However, I am not familiarized with swak4Foam either with groovyBC. After some research, what I found on the net is too vague for me (I am beginning to learn OpenFOAM). Could you please be more explicit about how to implement this incompressible heat flux boundary condition (For laminar flow it possible)?
Thanks in advance.
JLS is offline   Reply With Quote
boundary condition, boussinesq, heat flux
sliding mesh problem in CFX Saima CFX 46 September 11, 2021 08:38
Basic Nozzle-Expander Design karmavatar CFX 20 March 20, 2016 09:44
Problem in setting Boundary Condition Madhatter92 CFX 12 January 12, 2016 05:39
Enforce bounds error with heat loss boundary condition at solid walls Chander CFX 2 May 1, 2012 21:11
constant heat flux boundary condition manoj_1 Phoenics 0 June 27, 2010 14:07
