Unable to set reference cell for field p; Please supply either pRefCell or pRefPoi
Like Tree26Likes
  • 26 Post By Antimony
Old   February 5, 2017, 17:38
Default Unable to set reference cell for field p; Please supply either pRefCell or pRefPoi
UHGAR
UHGAR is on a distinguished road
Hello All,
I am getting this following error when I try to run an existing OpenFoam case setup. I request any of you to please advise on fixing this issue.
|  \\    /   O peration     | Version:  2.1.RG                                |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.1.RG
Exec   : cmcSIMPLEFoam
Date   : Feb 05 2017
Time   : 16:27:04
Host   : "lab"
PID    : 6207
Case   : /media/WorkData2017/CMC_OF/BFS_sim_sCO2_Tables_sCO2BC
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
Reading combustion properties
Reading thermophysical properties
Selecting thermodynamics package hPsiMixtureThermo<homogeneousMixture<sutherlandTransport<specieThermo<janafThermo<perfectGas>>>>>
Reading field U
Creating field T
create field c
create field cVar
--> FOAM FATAL IO ERROR:
    Please supply either pRefCell or pRefPoint
file: /media/WorkData/DOE_2017/CMC_OF/BFS_Carlos_sim_sCO2_Tables_sCO2BC/system/fvSolution::SIMPLE from line 117 to line 117.
    From function void Foam::setRefCell
    const volScalarField&,
    const dictionary&,
    label& scalar&,
    bool
    in file cfdTools/general/findRefCell/findRefCell.C at line 125.
FOAM exiting
UHGAR is offline   Reply With Quote
Old   February 6, 2017, 04:25
Antimony is on a distinguished road
My guess is that in 'p' you have given zeroGradient at all boundaries. From what I know you need to set value of pressure at least at one point so that you can get well-defined system that can be solved. Just add these two lines to your fvSolutions in the SIMPLE block:
pRefCell    0;
pRefValue    0;
Cheers,
Antimony
gaza, manishm.cfd, serles and 23 others like this.
Antimony is offline   Reply With Quote
Old   February 27, 2021, 10:00
Bushra Rasheed
B_R_Khan is on a distinguished road
Originally Posted by Antimony View Post
pRefCell    0;
pRefValue    0;
Cheers,
Antimony
Thank You for this! It really works!
However I don't know what values should I give in pRefCell and pRefValue. I got this error while using simpleFoam on lid driven cavity. Inserting this in Fv solutions removes the error but the results don't show any pressure contours . Is it the 0 pRefValue that is giving no pressure contours or is it something else?
Thanks
B_R_Khan is offline   Reply With Quote
Old   July 22, 2022, 13:08
PJmec45 is on a distinguished road
I've got the same problem
PJmec45 is offline   Reply With Quote
prefcell, prefpoint
Setting the height of the stream in the free channel kevinmccartin CFX 12 October 13, 2022 22:43
Sig Density Based Solver installation with FOAM Extend 3.2 qjh888 OpenFOAM Bugs 0 September 21, 2016 09:16
Simple piston movement in cylinder- fluid models arun1994 CFX 4 July 8, 2016 03:54
G95 + CGNS Bruno Main CFD Forum 1 January 30, 2007 01:34
Building OpenFoAm on SGI Altix 64bits anne OpenFOAM Installation 8 June 15, 2006 10:27
