fanPressure BC for a suction fan, how it works?
Like Tree2Likes
  • 1 Post By student666
Old   January 11, 2017, 19:21
Default fanPressure BC for a suction fan, how it works?
M. C.
student666 is on a distinguished road
Hi all,
I’m trying to better understand how to set properly bcs for pressure and velocity on a 2D laminar case (rectangular channel 3x0.3x0.1 ), using OF v4.1, with fanPressure bc on the outlet patch.
Test case is as for enclosed picture.
fanPressure.C source code is
// Average volumetric flow rate
    scalar volFlowRate = 0;
    if (phi.dimensions() == dimVelocity*dimArea)
        volFlowRate = dir*gSum(phip);
    else if (phi.dimensions() == dimVelocity*dimArea*dimDensity)
        const scalarField& rhop =
            patch().lookupPatchField<volScalarField, scalar>(rhoName());
        volFlowRate = dir*gSum(phip/rhop);
I set the following flowrate/pressureDrop fanCurve.
5((0.0005 6)(0.001 5)(0.0017 4.5)(0.0022 4)(0.0028 1))
As fanPressureBC sets a pressure condition on outlet, I set for U the following BC:
    inlet
        type           outletInlet;
        phi            phi;
        outletValue    uniform (0 0 0);
        value          uniform (0 0 0);
    outlet
	type            pressureInletOutletVelocity;
and this is p file:
    inlet
        type            fixedValue;
	value		uniform 0;
    outlet
        type            fanPressure;
        fileName        "fanCurve";
        outOfBounds     clamp;
        direction       out;
	U		U;
	phi		phi;
//	psi		none;
//	rho		rho;
        p0              uniform 0;
        value           uniform 0;
when I run simpleFoam for 1000iterations I have the following last log:
Time = 1000
smoothSolver:  Solving for Ux, Initial residual = 1.512615e-05, Final residual = 5.2722318e-08, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 8.228806e-05, Final residual = 2.0212224e-07, No Iterations 1
GAMG:  Solving for p, Initial residual = 0.00017614954, Final residual = 1.6843817e-05, No Iterations 1
time step continuity errors : sum local = 7.2177518e-06, global = 1.5811468e-07, cumulative = -15.385409
ExecutionTime = 295.05 s  ClockTime = 308 s
and the residual is attached (run1)
this is the postProcess -func 'patchAverage(name=outlet,U)' output for latestTime:
Time = 1000
Reading fields:
    volVectorFields: U
Executing functionObjects
surfaceRegion patchAverage(name=outlet,U) write:
    average(outlet) of U = (50.051912 -6.985344e-05 0)
Impossible: Out Of Bound Solution!
If I reverse outlet with inlet, so in order to have the fan to blow inside the channel with following BC:
U
    inlet
        type           inletOutlet;
        phi            phi;
        inletValue     uniform (0 0 0);
    outlet
and for p:
    inlet
        type            fixedValue;
	value		uniform 0;
    outlet
        type            fanPressure;
        outOfBounds     clamp;
        direction       in;
	U		U;
	phi		phi;
//	psi		none;
//	rho		rho;
        p0              uniform 0;
        value           uniform 0;
I get following outoput for postProcess -func 'patchAverage(name=inlet,U)':
Time = 1000
Reading fields:
    volVectorFields: U
surfaceRegion patchAverage(name=inlet,U) write:
    average(inlet) of U = (-1.3472552 -1.511e-11 0)
Reasonable...even if you calculate 1.347*0.3*0.1=4,02×10⁻² m3/s (still out of bound, but less...)
So the question is, how to make this BC works for a suction fan? what am I missing?
Thanks.
Michele
raj kumar saini likes this.
student666 is offline   Reply With Quote
Old   January 18, 2017, 12:47
M. C.
Hi all,
I performed some test.
In summary, I increased the mesh resolution, but my opinion is that average velocity is still out of bound.
As according to the fan curve I set, the resuting velocity cannot exceed 0.0028 [cm/s] /0.3 [m]/0.1 [m] = 0.093 m/s.
I also tried to change fvScheme, using Van Leer limited for U divScheme e.g. but I still have too high velocity.
Am I doing right?
Modeling a Fan by the Multiple reference frame (MRF) method in CFX. saisanthoshm88 CFX 11 February 17, 2021 12:30
CFX a vibration fan at a shell space kevin8843 CFX 15 November 7, 2013 22:42
Modeling of a HVAC Fan Evona FLUENT 0 May 1, 2013 04:15
Boundary conditions for a Fan geometry saisanthoshm88 CFX 9 February 7, 2011 05:33
Fan boundary condition. Alex FLUENT 0 December 1, 2006 12:48
