How does OpenFOAM calculate displacements?
Like Tree1Likes
  • 1 Post By floquation
Old   January 10, 2017, 13:34
Default How does OpenFOAM calculate displacements?
Man108 is on a distinguished road
Hi all,
I'm a beginner of OpenFOAM. I'm trying to implement a square section (2D) with aeroelastic behaviour. I use the solver pimpleDyMFoam and I want to insert a specific stiffness along the direction Y. I suppose that OpenFOAM solves the equation F=Ku+cU+ma where F is the vector of forces, K is the stiffness matrix and u is the vector of dispacements, is it right? The problem is that I don't find where OpenFOAM does this and so I can't modify the stiffness matrix as I want.
Thanks a lot!!
Man108 is offline   Reply With Quote
Old   January 11, 2017, 04:51
floquation's Avatar
Kevin van As
floquation will become famous soon enough
I don't know, but this might get you started in finding it:
Using "grep" you can search the OF source tree recursively for the keywords that you are looking for.
For instance, if you go to $FOAM_SRC/dynamicFvMesh (OF40), you might search for:
grep -rn "displac" .
Also look at $FOAM_SRC/dynamicMesh (OF40).
In your case directory, you may find what mesh is being used in "constant/dynamicMeshDict". Using that information may limit your search.
Man108 likes this.
floquation is offline   Reply With Quote
Old   January 11, 2017, 07:02
Thanks for your help Kevin!! If I find something, I'll write it here.
displacements, pimpledymfoam, stiffness
OpenFOAM v3.0+ ?? SBusch OpenFOAM 22 December 26, 2016 15:24
UNIGE February 13th-17th - 2107. OpenFOAM advaced training days joegi.geo OpenFOAM Announcements from Other Sources 0 October 1, 2016 20:20
OpenFOAM Training Jan-Apr 2017, Virtual, London, Houston, Berlin cfd.direct OpenFOAM Announcements from Other Sources 0 September 21, 2016 12:50
Calculate aerodynamic coefficients with openfoam using only opensource programs Xwang OpenFOAM 20 May 20, 2016 12:26
[Commercial meshers] How To Use OpenFOAM Software To Calculate Pump? renyun0511 OpenFOAM Meshing & Mesh Conversion 2 August 30, 2009 22:49
