blockMesh error: ill defined primitiveEntry starting at keyword 'vertices'
Like Tree1Likes
  • 1 Post By mgab
Old   December 4, 2016, 06:10
Default blockMesh error: ill defined primitiveEntry starting at keyword 'vertices'
mgab is on a distinguished road
I'm trying to make a simulation of a laminar flow around a cylinder.
This is my blockMeshDict
|  \\    /   O peration     | Version:  4.1                                   |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      blockMeshDict;
convertToMeters 0.1;
vertices
    (0.5 0 -0.5)
    (1 0 -0.5)
    (10 0 -0.5)
    (10 0.707107 -0.5)
    (0.707107 0.707107 -0.5)
    (0.353553 0.353553 -0.5)
    (10 2 -0.5)
    (0.707107 2 -0.5)
    (0 2 -0.5)
    (0 1 -0.5)
    (0 0.5 -0.5)
    (-0.5 0 -0.5)
    (-1 0 -0.5)
    (-2 0 -0.5)
    (-2 0.707107 -0.5)
    (-0.707107 0.707107 -0.5)
    (-0.353553 0.353553 -0.5)
    (-2 2 -0.5)
    (-0.707107 2 -0.5)
    (0.5 0 0.5)
    (1 0 0.5)
    (10 0 0.5)
    (10 0.707107 0.5)
    (0.707107 0.707107 0.5)
    (0.353553 0.353553 0.5)
    (10 2 0.5)
    (0.707107 2 0.5)
    (0 2 0.5)
    (0 1 0.5)
    (0 0.5 0.5)
    (-0.5 0 0.5)
    (-1 0 0.5)
    (-2 0 0.5)
    (-2 0.707107 0.5)
    (-0.707107 0.707107 0.5)
    (-0.353553 0.353553 0.5)
    (-2 2 0.5)
    (-0.707107 2 0.5)
    (10 -0.707107 -0.5)
    (0.707107 -0.707107 -0.5)
    (0.353553 -0.353553) -0.5)
    (10 -2 -0.5)
    (0.707107 -2 -0.5)
    (0 -2 -0.5)
    (0 -1 -0.5)
    (0 -0.5 -0.5)
    (-2 -0.707107 -0.5)
    (-0.707107 -0.707107 -0.5)
    (-0.353553 -0.353553 -0.5)
    (-2 -2 -0.5)
    (-0.707107 -2 -0.5)
    (10 -0.707107 0.5)
    (0.707107 -0.707107 0.5)
    (0.353553 -0.353553 0.5)
    (10 -2 0.5)
    (0.707107 -2 0.5)
    (0 -2 0.5)
    (0 -1 0.5)
    (0 -0.5 0.5)
    (-2 -0.707107 0.5)
    (-0.707107 -0.707107 0.5)
    (-0.353553 -0.353553 0.5)
    (-2 -2 0.5)
    (-0.707107 -2 0.5)
blocks
    hex ( 5 4 9 10 24 23 28 29 ) ( 80 20 1 ) simpleGrading ( 10 1 1 )
    hex ( 0 1 4 5 19 20 23 24 ) ( 80 20 1 ) simpleGrading ( 10 1 1 )
    hex ( 1 2 3 4 20 21 22 23 ) ( 200 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 4 3 6 7 23 22 25 26 ) ( 200 40 1 ) simpleGrading ( 1 1 1 )
    hex ( 9 4 7 8 28 23 26 27 ) ( 20 40 1 ) simpleGrading ( 1 1 1 )
    hex ( 1 6 10 9 15 35 29 28 34 ) ( 20 80 1 ) simpleGrading ( 1 10 1 )
    hex ( 1 1 16 15 12 30 35 34 31 ) ( 20 80 1 ) simpleGrading ( 1 10 1 )
    hex ( 1 2 15 14 13 31 34 33 32 ) ( 20 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 1 5 18 17 14 34 37 36 33 ) ( 40 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 9 8 18 15 28 27 37 34 ) ( 40 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 40 45 44 39 53 58 57 52 ) ( 20 80 1 ) simpleGrading ( 1 10 1 )
    hex ( 0 40 39 1 19 53 52 20 ) ( 20 80 1 ) simpleGrading ( 1 10 1 )
    hex ( 1 39 38 2 20 52 51 21 ) ( 20 200 1 ) simpleGrading ( 1 1 1 )
    hex ( 39 42 41 38 52 55 54 51 ) ( 40 200 1 ) simpleGrading ( 1 1 1 )
    hex ( 44 43 42 39 57 56 55 52 ) ( 40 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 48 47 44 45 61 60 57 58 ) ( 80 20 1 ) simpleGrading ( 10 1 1 )
    hex ( 11 12 47 48 30 31 60 61 ) ( 80 20 1 ) simpleGrading ( 10 1 1 )
    hex ( 12 13 46 47 31 32 59 60 ) ( 20 20 1 ) simpleGrading ( 1 1 1 )
    hex ( 47 46 49 50 60 59 62 63 ) ( 20 40 1 ) simpleGrading ( 1 1 1 )
    hex ( 44 47 50 43 57 60 63 56 ) ( 20 40 1 ) simpleGrading ( 1 1 1 )
edges
    arc 0 5 ( 0.469846 0.17101 -0.5)
    arc 5 10 ( 0.17101 0.469846 -0.5)
    arc 1 4 ( 0.939693 0.34202 -0.5)
    arc 4 9 ( 0.34202 0.939693 -0.5)
    arc 19 24 ( 0.469846 0.17101 0.5 )
    arc 24 29 ( 0.17101 0.469846 0.5 )
    arc 20 23 ( 0.939693 0.34202 0.5 )
    arc 23 28 ( 0.34202 0.939693 0.5 )
    arc 11 16 ( -0.469846 0.17101 -0.5)
    arc 16 10 ( -0.17101 0.469846 -0.5)
    arc 12 15 ( -0.939693 0.34202 -0.5)
    arc 15 9 ( -0.34202 0.939693 -0.5)
    arc 30 35 ( -0.469846 0.17101 0.5 )
    arc 35 29 ( -0.17101 0.469846 0.5 )
    arc 31 34 ( -0.939693 0.34202 0.5 )
    arc 34 28 ( -0.34202 0.939693 0.5 )
    arc 0 40 ( 0.469846 -0.17101 -0.5)
    arc 40 45 ( 0.17101 -0.469846 -0.5)
    arc 1 39 ( 0.939693 -0.34202 -0.5)
    arc 39 44 ( 0.34202 -0.939693 -0.5)
    arc 19 53 ( 0.469846 -0.17101 0.5 )
    arc 53 58 ( 0.17101 -0.469846 0.5 )
    arc 20 52 ( 0.939693 -0.34202 0.5 )
    arc 52 57 ( 0.34202 -0.939693 0.5 )
    arc 11 48 ( -0.469846 -0.17101 -0.5)
    arc 48 45 ( -0.17101 -0.469846 -0.5)
    arc 12 47 ( -0.939693 -0.34202 -0.5)
    arc 47 44 ( -0.34202 -0.939693 -0.5)
    arc 30 61 ( -0.469846 -0.17101 0.5 )
    arc 61 58 ( -0.17101 -0.469846 0.5 )
    arc 31 60 ( -0.939693 -0.34202 0.5 )
    arc 60 57 ( -0.34202 -0.939693 0.5 )
boundary
    top
        type symmetryPlane ;
        faces
            ( 7 8 27 26 )
            ( 6 7 26 25 )
            ( 8 18 37 27 )
            ( 18 17 36 37 )
    bottom
        faces
            ( 49 50 63 62 )
            ( 50 43 56 63 )
            ( 43 42 55 56 )
            ( 42 41 54 55 )
    inlet
        type patch ;
        faces
            ( 14 13 32 33 )
            ( 17 14 33 36 )
            ( 46 13 32 59 )
            ( 46 49 62 59 )
    outlet
        type patch ;
        faces
            ( 2 3 22 21 )
            ( 3 6 25 22 )
            ( 38 51 21 2 )
            ( 41 54 51 38 )
    cylinder
        type wall ;
        faces
            ( 10 5 24 29 )
            ( 50 19 24 )
            ( 16 10 29 35 )
            ( 11 16 35 30 )
            ( 48 11 30 61 )
            ( 45 48 61 58 )
            ( 40 45 58 53 )
            ( 0 40 53 1 9 )
    frontAndBack
        type empty ;
        faces
            (5 10 9 4 )
            (24 23 28 29 )
            (0 5 4 1)
            (19 20 23 24 )
            (1 4 3 2)
            (20 21 22 23 )
            (4 7 6 3)
            (23 22 25 26 )
            (4 9 8 7)
            (28 23 26 27 )
            (16 15 9 10 )
            (35 29 28 34 )
            (12 15 16 11 )
            (31 30 35 34 )
            (13 14 15 12 )
            (32 31 34 33 )
            (14 17 18 15 )
            (33 34 37 36 )
            (15 18 8 9 )
            (34 28 27 37 )
            (45 40 39 44 )
            (58 57 52 53 )
            (40 0 1 39)
            (53 52 20 19 )
            (39 1 2 38)
            (52 51 21 20 )
            (39 38 41 42 )
            (52 55 54 51 )
            (44 39 42 43)
            (57 56 55 52 )
            (47 48 45 44 )
            (60 57 58 61 )
            (12 11 48 47 )
            (31 60 61 30 )
            (13 12 47 46 )
            (32 59 60 31 )
            (49 46 47 50 )
            (62 63 60 59 )
            (50 47 44 43 )
            (63 56 57 60 )
mergePatchPairs
When i run blockMesh my terminal gives:
--> FOAM FATAL IO ERROR:
"ill defined primitiveEntry starting at keyword 'vertices' on line 20 and ending at line 280"
file: /home/marco/OpenFOAM/marco-4.1/run/cylinder195/constant/polyMesh/blockMeshDict at line 280.
I checked multiple times but i don't find anything wrong and also my blockMeshDict file is 272 lines long.
Please, help me to figure out this.
Thanks.
I found the mistake. It was a simple typo. Thanks anyway!
Sud09463 likes this.
mgab is offline   Reply With Quote
Old   January 24, 2017, 01:59
Default ill defined primitiveEntry starting at keyword 'vertices' on line 21 and ending at li
sudhakar singh
Sud09463 is on a distinguished road
Hello mgab,
Can you please look into this blockMesh file and figure out the error. i am stuck into this and i am not able to figure it out
"ill defined primitiveEntry starting at keyword 'vertices' on line 21 and ending at line 107"
file: /home/sud/mmcRun/CH4D60/constant/polyMesh/blockMeshDict at line 107.
From function primitiveEntry::readEntry(const dictionary&, Istream&)
in file lnInclude/IOerror.C at line 132.
FOAM exiting
BlockMeshDict:
convertToMeters 0.001;
vertices
(-22.85 -22.85 0) //0
(22.85 -22.85 0) //1
(22.85 22.85 0) //2
(-22.85 22.85 0) //3
(-91.40 -91.40 0) //4
(91.40 -91.40 0 //5
(91.40 91.40 0) //6
(-91.40 91.40 0) //7
(-22.85 -22.85 470) //8
(22.85 -22.85 470) //9
(22.85 22.85 470) //10
(-22.85 22.85 470) //11
(-91.40 -91.40 470) //12
(91.40 -91.40 470) //13
(91.40 91.40 470) //14
(-91.40 91.40 470) //15
blocks
hex (0 1 2 3 8 9 10 11) (40 40 240) simpleGrading (1 1 1) //centre
hex (3 2 6 7 11 10 14 15) (40 40 240) simpleGrading (1 1 1) //top
hex (4 0 3 7 12 8 11 15) (40 40 240) simpleGrading (1 1 1) //left
hex (5 1 0 4 13 9 8 12) (40 40 240) simpleGrading (1 1 1) //bottom
hex (5 6 2 1 13 14 10 9) (40 40 240) simpleGrading (1 1 1) //right
edges
boundary
outlet
type patch;
physicalType particleOutflow;
faces
(11 10 9 8)
(15 14 10 11)
(15 11 8 12)
(8 9 13 12)
(10 14 13 9)
side
type patch;
faces
(6 5 13 14)
(7 6 14 15)
(4 7 15 12)
(5 4 12 13)
inletCoflow
type patch;
physicalType noParticleOutflow;
faces
(0 1 2 3)
(2 6 7 3)
(3 7 4 0)
(0 4 5 1)
(1 5 6 2)
mergePatchPairs
Sud09463 is offline   Reply With Quote
Old   January 24, 2017, 02:11
Antimony is on a distinguished road
(91.40 -91.40 0 //5
This line is missing )
Put it in and you should be good to go.
Cheers,
Antimony
Antimony is offline   Reply With Quote
Old   January 24, 2017, 04:03
sudhakar singh
Hello Antimony,
now it is working. thanku so much for your quick reply.
sudhakar singh
blockmesh, blockmeshdict, openfoam, vertices
big difference between clockTime and executionTime LM4112 OpenFOAM Running, Solving & CFD 21 February 15, 2019 04:05
[blockMesh] "ill defined primitiveEntry starting at keyword Boundary ..... Punt3r OpenFOAM Meshing & Mesh Conversion 3 June 12, 2016 10:16
[blockMesh] blockMesh error ill defined primitiveEntry starting at keyword 'blocks' ihu945 OpenFOAM Meshing & Mesh Conversion 1 June 7, 2016 22:56
icoFoam: ill defined primitiveEntry starting at Keyword 'value' sinatahmooresi OpenFOAM Running, Solving & CFD 4 December 20, 2015 15:14
[blockMesh] Can't find my mistake blockMeshDict jelzinga OpenFOAM Meshing & Mesh Conversion 8 March 19, 2015 02:08
