Superimposing Sinusoidal Perturbations at Inlet
Like Tree1Likes
  • 1 Post By HenningW
Old   August 23, 2016, 06:11
Question Superimposing Sinusoidal Perturbations at Inlet
Harnoor Singh
Harnoor is on a distinguished road
Hi all,
I am trying to simulate a hot rising plume inside a cylindrical domain using buoyantBoussinesqPimpleFoam. But, the plume fails to transition inside the computational domain (since my Re is not very large). I read in a NASA research paper that you need to superimpose sinusoidal perturbations (corresponding to the most unsteady mode as per stability analysis) at the inlet velocity/temperature in order to achieve faster transition. This way I can capture turbulent regime inside my computational domain.
I am a beginner in OpenFoam and request someone to please tell me in detail "How I can superimpose sinusoidal perturbations at inlet velocity/temperature".
Tnx in advance.
Harnoor is offline   Reply With Quote
Old   August 23, 2016, 06:18
Harnoor Singh
I basically want to get an unsteady inlet BC as follows -
U_z = U_z + A sin(omega * t)
Old   August 25, 2016, 11:49
HenningW is on a distinguished road
I think what you are looking for is swak4foam and more specifik the groovyBC package it includes.
If installed (do not remember if it always is included), you should insert
libs (
      "libOpenFOAM.so"
      "libsimpleSwakFunctionObjects.so"
      "libswakFunctionObjects.so"
      "libgroovyBC.so"
in your system/controlDict.
In your 0/U you should set your BC (lets say its named "inlet") like:
   inlet
     type            groovyBC;
     variables (
                       "U_x=10;"
                       "U_y=10;"
                       "U_z=10;"
                       "A=20;"
                       "f=50;"
                       "omega=2*pi*f;"
     valueExpression "vector(U_x, U_y, U_z+A*sin(omega*time()))";
     value           uniform (0 0 0); // As far as I remember, this has to be here, but does nothing and can be ignored
Of course you have to adapt your values. I haven't tested it, due to the lack of time, but it should set you up to a good start, I think. However, let me know if it worked or if you need additional help.
Also check out the following pages on the use of swak4foam/groovyBC:
https://openfoamwiki.net/index.php/Contrib/swak4Foam
http://openfoamwiki.net/index.php/Contrib/groovyBC
dkjiao likes this.
HenningW is offline   Reply With Quote
buoyantboussinesqpimple, inlet bc, perturbation, plume, sinusoidal
setting the correct format of nonuniform List<vector> for inlet in 0 Folder cfdonline2mohsen OpenFOAM Running, Solving & CFD 8 July 18, 2019 09:03
Total pressure and mass flow boundary condition at inlet bscphil OpenFOAM Pre-Processing 3 July 9, 2017 15:39
Inlet Velocity in CFX aeroman CFX 12 August 6, 2009 19:42
Diffusion component at inlet Balaji FLUENT 2 August 8, 2005 08:37
length scales at inlet for internal flows Anne-Marie Giroux Main CFD Forum 3 July 5, 1999 22:28
