flow over cylinder
Like Tree1Likes
  • 1 Post By Tobi
Old   August 11, 2016, 20:04
Default flow over cylinder
jafar
bagherij is on a distinguished road
Hi
i am working on flow past cylinder with Re=0 ,i attached geometry .there are no require set pressure boundary at AB and BC ,how can i implement it in 0/p?i set it as below but no working fine.please help
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class volScalarField;
object p;
dimensions [0 2 -2 0 0 0 0];
internalField uniform 1;
boundaryField
left
type symmetryPlane;
right
type fixedValue;
value uniform 0;
down
type symmetryPlane;
up
type zeroGradient;
cylinder
type zeroGradient;
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class volVectorField;
object U;
dimensions [0 1 -1 0 0 0 0];
internalField uniform (0 0 0);
boundaryField
left
type symmetryPlane;
right
type fixedValue;
value uniform (0 1 0);
down
type symmetryPlane;
up
type fixedValue;
cylinder
type fixedValue;
value uniform (0 0 0);
frontAndBack
type empty;
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
p
solver GAMG;
tolerance 1e-6;
relTol 0;
smoother GaussSeidel;
nPreSweeps 2;
nPostSweeps 2;
cacheAgglomeration on;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
U
solver smoothSolver;
tolerance 1e-6;
relTol 0;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefPoint (2,0,0);
pRefCell 0;
residualControl
p 1e-3;
U 1e-4;
relaxationFactors
fields
p 0.3;
equations
U 0.7;
bagherij is offline   Reply With Quote
Old   August 12, 2016, 09:35
HenningW is on a distinguished road
I am not sure what you mean by Re=0. So there is no flow at all?
Can please provide an error message or what exactly is not working?
HenningW is offline   Reply With Quote
Old   August 12, 2016, 09:45
On the right hand side you have a symmetry wall, yet you want a flow perpendicular to it? I do not think thats physically possible. Correct me if I am wrong, by in a symmetry plane the mass-flow should be 0 and thus the stream lines need to parallel to the surface, otherwise you have a line with mass constantly flowing in from both sides. Where is the fluid supposed to go without removing mass or compressing it to infinity?
Old   August 12, 2016, 12:47
jafar
Dear
there was some mistake in the picture,i changed it.
the flow is non-newtonnian (creeping flow like foams , filled polymer solution ) therefore re<<1, i attached the governing equations .the problem considered with two planes of symmetry, hence one quater of the domain is used,also i attached the all domain.
Thanks
Old   August 13, 2016, 05:50
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Hi all,
  • first I did not check you first post because there are missing code-tags.
  • out of the last post, you have to implement a few stuff yourself.
  • I am not sure if eqn. 9 and 10 are correct (you should derive this yourself to be sure).
  • If the viscosity model is not implemented in foam, you have to implement it yourself.
  • based on your domain, you need to set the pRefValue in fvSolutions. Otherwise it will not work because you are not defining a well constrained problem.
Finally it is exact that one here: http://www.holzmann-cfd.de/index.php...gelumstroemung
But in your case it is a non-newtonian flow. Based on the tensors and fluid behaviors, maybe you are allowed to simplify the deviatoric stress tensor to get a Poisson equation but maybe it is not possible. Anyway (:
bagherij likes this.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   August 13, 2016, 17:59
jafar
Dear Tobi
I attach the domain ,I dont want to apply pressure boundary condition at AB(up) and BC (right) ,how can i do it in the codes?
object p;
boundaryField
left
type symmetryPlane;
right
?????????????what should i write???
up
Old   August 13, 2016, 18:28
Tobi's Avatar
Tobias Holzmann
First guess,
  • right -> p :: zeroGradient
  • up -> p :: zeroGradient
set the refPressure close to the symmetry point and try.
PS: I am not sure if you can simplify the case in that way. It should be wrong if I think about it. You should have 2 symmetryPlanes but could it be that you have 3. ?
Keep foaming,
Tobias Holzmann
openfoam 2.1, pressure boundary, velocity boundary
Drag force coefficient too low for a flow past cylinder at Re= 1e05 Scabbard STAR-CCM+ 2 June 5, 2020 15:44
Flow past a cylinder at Re 1e05 using LES, drag force coefficient is to low Scabbard Main CFD Forum 21 June 19, 2018 14:58
Flow around cylinder free to rotate Jonas Holdeman Main CFD Forum 5 August 3, 2015 18:54
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 12:47
Flow over a cylinder Anna Main CFD Forum 9 March 24, 2006 15:32
