August 4, 2016, 11:44 |
mapFields for non-consitent geometry
Amelie Rohlfs
Rep Power: 13 |
Hello dear OpenFoam-friends,
My problem looks like this: I have a fluid solution which I want to map on a solid. Have a look at the first attached picture. The blue part is my internal fluid region, the green part was left out during the simulation. The green part is my solid blade, where I want to map for example the pressure field. Due to different reasons the fluid-blade geometry is slightly different to my solid-blade geometry. When I execute mapFields I get the result in picture 2. The mapping works fine for the cells where my solid blade is slighty larger or same size as my fluid boundaries. Sometimes there is a gap between fluid and solid, there the mapping does not work. My questions: 1. can I solve this problem within mapFields? 2. or is there a way to "stretch" my solid blade for example 1 mm in each direction so that it gets a bit larger. I know of "scale", but as my geometry is not axissymetric I could not figure out how to do that. Thank you very much for any ideas! Amelie |
August 5, 2016, 02:26 |
Amelie Rohlfs
Rep Power: 13 |
I might have found a solution already within mapFields. The default mapMethod is cellVolumeWeight. Now I tried -mapMethod mapNearest, which seems to work fine for my problem.
Running CFD parallel. There is no geometry file! | CrashLaker | SU2 | 6 | April 10, 2014 03:08 |
[CAD formats] translating geometry from Abaqus to OpenFOAM | skuznet | OpenFOAM Meshing & Mesh Conversion | 3 | January 10, 2014 13:49 |
Geometry for Confined Circular Jet | Greatness | FLUENT | 0 | October 1, 2013 05:04 |
Problem Importing Geometry ProE to CFX | fatb0y | CFX | 3 | January 14, 2012 19:42 |
2D geometry to 3D geometry | Sgonzalezg | ANSYS Meshing & Geometry | 11 | April 8, 2011 11:02 |
