decomposePar does not work
Like Tree1Likes
  • 1 Post By fabian_roesler
Old   October 22, 2015, 04:01
Smile decomposePar does not work
Priya Somasundaran
Priya Somasundaran is on a distinguished road
I am trying to run a model with 14596 cells with 3 node and one processor each using parellel computing. My parallel computing was tested and is working fine when I tested for the pitZDaily example from the tutorial.
But when I am trying to decompose the model with 14596 cells I get the following error
Decomposing mesh region0
Create mesh
Calculating distribution of cells
Selecting decompositionMethod hierarchical
Finished decomposition in 8.27 s
Calculating original mesh data
Distributing cells to processors
Distributing faces to processors
Distributing points to processors
Constructing processor meshes
new cannot satisfy memory request.
This does not necessarily mean you have run out of virtual memory.
It could be due to a stack violation caused by e.g. bad use of pointers or an out of date shared library
Aborted (core dumped)
I am using the same decomposeParDict which I used to decompose the pitZDaily case
numberOfSubdomains 3;
method hierarchical;
simpleCoeffs
n (3 1 1);
delta 0.001;
hierarchicalCoeffs
n (3 1 1);
delta 0.001;
order xyz;
Any help would be much appreciated .
Priya Somasundaran is offline   Reply With Quote
Old   October 26, 2015, 05:46
Fabian Roesler
fabian_roesler is on a distinguished road
Hi
Is it a 2D case? Cause decomposePar doesn't like decomposing in the empty direction.
You could also try the decomposing method scotch.
method scotch;
Priya Somasundaran likes this.
fabian_roesler is offline   Reply With Quote
Old   October 26, 2015, 23:41
Default CFD decomposePar
Priya Somasundaran
Thanks fro responding. It is a 3D buildings mesh. And contrary to what I wrote there are 6331789 cells distributed in each of the processors. I have 3 nodes with one processor each with master having 32 GB of memory and the slaves 16 each.
I tried to use scotch distribution method also , but but a smiliar memory error. Now I am trying to run the distributionPar using MPIRUN so that i can distibute the mesh parallel. But failed.
| \\ / O peration | Version: 2.4.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 2.4.0-f0842aea0e77
Exec : redistributePar -parallel
Date : Oct 26 2015
Time : 17:58:48
Host : "Geoscience-PC"
PID : 10202
Case : /quest_cluster/home/quest/OpenFOAM/quest-2.4.0/run/simulation
nProcs : 3
Slaves :
2
"Quest-2.14289"
"Quest-1.28844"
Pstream initialized with:
floatTransfer : 0
nProcsSimpleSum : 0
commsType : nonBlocking
polling iterations : 0
allowSystemOperations : Allowing user-supplied system call operations
--> FOAM Warning :
From function redistributePar
in file redistributePar.C at line 444
Detected floating point exception trapping (FOAM_SIGFPE). This might give
problems when mapping fields. Switch it off in case of problems.
Create time
Using mesh subdirectory "polyMesh"
Found points in "/quest_cluster/home/quest/OpenFOAM/quest-2.4.0/run/simulation/processor0/constant/polyMesh"
Per processor mesh availability : 3{1}
Boundary definition OK.
Before distribution:
Processor 0
Number of cells = 6331789
Number of processor patches = 0
Number of processor faces = 0
Number of boundary faces = 1366151
Processor 1
Processor 2
Max number of cells = 6331789 (0% above average 6.33179e+06)
Max number of processor patches = 0 (-100% above average 1)
Max number of faces between processors = 0 (-100% above average 1)
Writing wanted cell distribution to volScalarField decomposition for postprocessing purposes.
Merge tolerance : 1e-06
Write tolerance : 1e-06
Overall meshes bounding box : (16700 34600 0) (18000 36000 500)
Relative tolerance : 1e-06
Absolute matching distance : 0.00197484
[Quest-1:28844] *** Process received signal ***
[Quest-1:28844] Signal: Aborted (6)
[Quest-1:28844] Signal code: (-6)
[Quest-1:28844] *** End of error message ***
[Quest-2:14289] *** Process received signal ***
[Quest-2:14289] Signal: Aborted (6)
[Quest-2:14289] Signal code: (-6)
[Quest-2:14289] *** End of error message ***
mpirun noticed that process rank 2 with PID 28844 on node 192.168.1.107 exited on signal 6 (Aborted).
Any clues ? AM I still short of memory ?
Old   October 27, 2015, 02:57
Fabian Roesler
Well, 7M Cells should be possible on 32 GB memory. Parallel decomposition is not possible. You have to decompose single core on your master node.
You could top your memory usage while decomposing.
Have you tried running single core on the master node?
Cheers
Fabian
[mesh manipulation] Some questions on blockMesh, decomposePar and renumberMesh Leech OpenFOAM Meshing & Mesh Conversion 19 April 5, 2019 20:21
How to run decomposePar with parMetis? xiaow_g OpenFOAM Pre-Processing 16 July 8, 2017 14:37
How to run decomposePar with parMetis? xiaow_g OpenFOAM Running, Solving & CFD 1 March 27, 2012 04:39
Why do the Plant library cases don't work? Alumna Phoenics 6 June 22, 2004 13:08
why my In-Form doesn't work? green Phoenics 2 May 27, 2004 22:03
