hemisphere in setFields
Like Tree1Likes
  • 1 Post By nimasam
Old   October 8, 2015, 23:53
Default hemisphere in setFields
Elham
Elham is on a distinguished road
I am going to simulate a single droplet falling in air by means of InterDyMFoam. To decrease the computational time I want to simulate half of the domain. So I need to have a hemisphere for the half of the drop in initial condition. Anybody knows How I can create a hemisphere by setFields or any other functions?
Thanks
Elham is offline   Reply With Quote
Old   October 10, 2015, 09:21
Nima Samkhaniani
nimasam is on a distinguished road
you can use following instructions :
defaultFieldValues
volScalarFieldValue alpha1 1
regions
sphereToCell
centre (0 0 1.024E-03);
radius 0.512E-03;
fieldValues
volScalarFieldValue alpha1 0
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 11, 2015, 12:44
kmooney's Avatar
Kyle Mooney
kmooney is on a distinguished road
Setting a sphere should work in your case right?
kmooney is offline   Reply With Quote
Old   October 12, 2015, 00:26
Elham
Dear Nima,
Thanks for your reply. But I suppose it is for a sphere simulation not a hemisphere, isn't it?
Regards
Old   October 12, 2015, 02:11
Antimony is on a distinguished road
To make it a hemisphere, one can probably use a box to reset its value, I suppose.
Of course, this wouldn't be ideal if the plane of the flat surface of the hemisphere is at an angle.
Maybe combining it with topoSet and its rotated Box might help? Any comments?
Antimony is offline   Reply With Quote
Old   October 12, 2015, 09:11
Nima Samkhaniani
1- change your perspective , you can easily obtain hemispherical with that command Hint: assign a valid centre!
2- but if you insist on draw hemisphere, use funkySetFields
Elham likes this.
setFields after snappyHexMesh mo.houssami OpenFOAM Pre-Processing 4 May 13, 2015 12:44
rhoSimplecFoam with setFields sino75 OpenFOAM Pre-Processing 0 March 11, 2015 05:08
Problems with the execution of the setFields utility. foamer OpenFOAM Pre-Processing 5 June 3, 2013 13:24
Expanding and contracting hemisphere LvK FLUENT 0 August 26, 2010 03:35
hemisphere in channel flow kirill FLUENT 3 September 16, 2004 12:51
