T-junction multiphase
Like Tree1Likes
  • 1 Post By AOS
Old   September 4, 2015, 14:22
Default T-junction multiphase
AOS
Alberta
AOS is on a distinguished road
Hello everybody,
I need your help
I am trying to simulate two-phase flow in T-junction channel with two inlets; one for oil and the other for water. I also have one outlet.
I tried interFoam as well as multiphaseEulerFoam but the problem was that water enters through the two inlet.
How can I make Openfoam simulate two different phases at the inlet ?
Thanks
Chuyu2 likes this.
AOS is offline   Reply With Quote
Old   September 5, 2015, 06:33
Saideep
Saideep is on a distinguished road
hi;
So, i was workin over T-junctions for some time.
If you need to have two different conditions for the inlet boundary or so you can just divide the entry faces into two different blocks so that one is independent from the other. however you can also use several external utilities like "swak4Foam" to set these typical boundary conditions but i guess splitting face into 2 different blocks is easier and straight forward.
hope this helps;
Saideep
Saideep is offline   Reply With Quote
Old   September 10, 2015, 14:05
AOS
Alberta
hi
First of all thank you for your replay.
Actually, I using gmsh to create a mesh and I have inletOil and Inletwater what I mean I used two different inlets conditions not only because they are not the same phase but also because I have a velocity in the x-direction and the other in y-direction.
Old   September 10, 2015, 14:37
Saideep
I am not familiar with gmesh.
But with blockMesh you can still do that. Divide your inlet into two faces ans specify the velocities at the inlet.
For example: inlet1 faces{0 1 2 3}, inlet2 faces {4 5 6 7};
inlet1
type fixedValue;
value uniform (x 0 0);
inlet2
type fixedValue;
value uniform (0 y 0);
Old   September 14, 2015, 04:29
Dominik Schmidt
dschmidt is on a distinguished road
As far as I understood, you don't need to split the inlets, cause you want to use one inlet only for water and the other one just for oil.
For that purpose, you control the phase fractions at boundaries with the "alpha"-files.
In interFoam you only have one alpha-file an switch between the phases with alpha 1/0.
https://github.com/OpenFOAM/OpenFOAM...apillaryRise/0
e.g.:
    inlet1
        type            fixedValue;
        value           uniform 0;
    inlet2
        type            fixedValue;
        value           uniform 1;
In multiphaseEulerFoam each phase has its own alpha file.
https://github.com/OpenFOAM/OpenFOAM...bubbleColumn/0
e.g.
alpha.oil...
    inlet1
        type            fixedValue;
        value           uniform 0;
    inlet2
        type            fixedValue;
        value           uniform 1;
alpha.water...
    inlet1
        type            fixedValue;
        value           uniform 1;
    inlet2
        type            fixedValue;
        value           uniform 0;
dschmidt is offline   Reply With Quote
Old   December 2, 2015, 03:50
Sripadaraja
Sripadaraja is on a distinguished road
Hi Everyone,
I am New to OpenFoam. I want to perform the same kind of simulation which Alberta mentioned. I am not sure which mesh is suitable. I am getting the following error. Pls help.
paramesh@HP-WS3:~/OpenFOAM/paramesh-3.0.0/run/tutorials/incompressible/icoFoam/TJunction_gmail$ blockMesh
| \\ / O peration | Version: 3.0.0 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
Build : 3.0.0-8b097f6d8dd9
Exec : blockMesh
Date : Dec 02 2015
Time : 13:15:22
Host : "HP-WS3"
PID : 5841
Case : /home/paramesh/OpenFOAM/paramesh-3.0.0/run/tutorials/incompressible/icoFoam/TJunction_gmail
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
--> FOAM Warning :
From function dlOpen(const fileName&, const bool)
in file POSIX.C at line 1179
dlopen error : libgroovyBC.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
From function dlLibraryTable:pen(const fileName&, const bool)
in file db/dynamicLibrary/dlLibraryTable/dlLibraryTable.C at line 99
could not load "libgroovyBC.so"
--> FOAM Warning :
dlopen error : libswakFunctionObjects.so: cannot open shared object file: No such file or directory
--> FOAM Warning :
could not load "libswakFunctionObjects.so"
--> FOAM FATAL ERROR:
Cannot open mesh description file
"/home/paramesh/OpenFOAM/paramesh-3.0.0/run/tutorials/incompressible/icoFoam/TJunction_gmail/system/blockMeshDict"
From function blockMesh
in file blockMeshApp.C at line 149.
FOAM exiting
-Sripadaraja
Sripadaraja is offline   Reply With Quote
interfoam, multiphase flow, multiphaseeulerfoam, t-junction pipe
Difference in flow distribution of single phase and multiphase analysis shivasluzz CFX 0 April 22, 2015 23:54
3D multiphase micro model: mixing effect of air and water at the T junction ehsanfareed FLUENT 2 March 22, 2015 23:29
[ICEM] Blocking strategy for sharp angle junction (Pipe) Daniel_Khazaei ANSYS Meshing & Geometry 6 February 19, 2015 12:31
Low Mach Number Compressible Multiphase Flows DarrenC CFX 10 May 26, 2014 09:52
Junction Box Anil CFX 2 June 27, 2006 11:18
