createPatch cyclic boundary condition
Like Tree1Likes
  • 1 Post By PeterShi
Old   August 31, 2015, 07:28
Default createPatch cyclic boundary condition
KateEisenhower is on a distinguished road
I have some trouble with creating cyclic patches using createPatch and hope to find some help here.
I am simulating a wind tunnel flow with an airfoil which spans from the front to the back patch of the tunnel. It is a 3D case, but very similar to a 2D case because the mesh doesn't change in the y direction.
I created the mesh with gmsh and used gmshToFoam to get it working with OpenFoam 2.3.1. This works great so far.
Now the U_y Residuals are bothering me. I think they stay way to high and think this is related to the definition of my boundary codes front and back. Hence I want to try cyclic boundary condition on these two patches.
I got the default createPatchDict and set it up as follows (please note my questions in the first line of the code too):
pointSync false; // What does this mean?
// Patches to create.
patches
        // Name of new patch
        name frontcy;
        // Dictionary to construct new patch from
        patchInfo
            type cyclic;
            neighbourPatch backcy;
            // Optional: explicitly set transformation tensor.
            // Used when matching and synchronising points.
            // transform rotational;
            // rotationAxis (1 0 0);
            // rotationCentre (0 0 0);
            // transform translational;
            // separationVector (0 0.1 0);
            // Optional non-default tolerance to be able to define cyclics
            // on bad meshes
            matchTolerance 0.1;
        constructFrom patches;
        patches (front); // front is my original front patch
        name backcy;
        patchInfo
            type cyclic;
            neighbourPatch frontcy;
            // separationVector (0 -0.1 0);
            matchTolerance 0.1;
        patches (back); // back is my original back patch
Does this file look right to you? I am particularly unsure about the section with the transformation tensor which is commented out. Do I need it, or what is it for? Do I need the matchTolerance option in my case?
When running createPatch in terminal I get the following. This is only the beginning of the output but I think you are getting the point. If necessary I can upload the complete output too.
Kates-MacBook-Pro:2D_hkverfeinert_cyclic kateeisenhower$ createPatch
|  \\    /   O peration     | Version:  2.3.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
Build  : 2.3.1-262087cdf8db
Exec   : createPatch
Date   : Aug 31 2015
Time   : 12:24:50
Host   : "Kates-MacBook-Pro.local"
PID    : 91192
Case   : /Users/kateeisenhower/Documents/gmsh/Daten/2D_hkverfeinert_cyclic
nProcs : 1
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create polyMesh for time = 0
Reading createPatchDict
Adding new patch frontcy as patch 7 from
    type            cyclic;
    matchTolerance  0.1;
Adding new patch backcy as patch 8 from
    type            cyclic;
    matchTolerance  0.1;
Moving faces from patch front to patch 7
Moving faces from patch back to patch 8
Doing topology modification to order faces.
Cannot find point in pts1 matching point 75283 coord:(-0.00588242 0.05 -0.0365509) in pts0 when using tolerance 0.000375467
Searching started from:0 in pts1
    Compared coord: (-0.00588281 0.05 -0.0392114) at index 0 with difference to point 0.00266053
    Compared coord: (-0.00588916 0.05 -0.0392308) at index 1 with difference to point 0.00267992
    Compared coord: (-0.00589583 0.05 -0.0392511) at index 2 with difference to point 0.0027003
    Compared coord: (-0.00590283 0.05 -0.0392725) at index 3 with difference to point 0.00272171
    Compared coord: (-0.00591018 0.05 -0.0392949) at index 4 with difference to point 0.00274421
Best regards,
Kate
KateEisenhower is offline   Reply With Quote
Old   September 6, 2015, 03:41
Yousef
ykanani is on a distinguished road
Hi, if your patches are not exactly identical, you cannot create Cyclic patch. use cyclicAMI instead.
please see this thread :
http://www.cfd-online.com/Forums/ope...port-icem.html
ykanani is offline   Reply With Quote
Old   August 14, 2018, 15:48
Peter Shi
PeterShi is on a distinguished road
patches
        name frontcy;
        patchInfo
            type cyclic;
            // on bad meshes
            matchTolerance 0.1;
        name backcy;
        patchInfo
            type cyclic;
            matchTolerance 0.1;
Exec   : createPatch
Date   : Aug 31 2015
Time   : 12:24:50
PID    : 91192
nProcs : 1
Create time
    type            cyclic;
    matchTolerance  0.1;
    type            cyclic;
    matchTolerance  0.1;
Best regards,
Kate
Hi Kate,
I met the exactly same problem as you, have you solved your problem yet? Thanks.
Best regards,
Peter
manuc likes this.
PeterShi is offline   Reply With Quote
Old   September 4, 2018, 15:30
clapointe is on a distinguished road
As mentioned previously, cyclicAMI patches are needed if the patches do not match exactly. I've used the following createPatchDict before to create cyclicAMI patches :
|  \\    /   O peration     | Version:  4.x                                   |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      createPatchDict;
// This application/dictionary controls:
// - optional: create new patches from boundary faces (either given as
//   a set of patches or as a faceSet)
// - always: order faces on coupled patches such that they are opposite. This
//   is done for all coupled faces, not just for any patches created.
// - optional: synchronise points on coupled patches.
// 1. Create cyclic:
// - specify where the faces should come from
// - specify the type of cyclic. If a rotational specify the rotationAxis
//   and centre to make matching easier
// - always create both halves in one invocation with correct 'neighbourPatch'
//   setting.
// - optionally pointSync true to guarantee points to line up.
// 2. Correct incorrect cyclic:
// This will usually fail upon loading:
//  "face 0 area does not match neighbour 2 by 0.0100005%"
//  " -- possible face ordering problem."
// - in polyMesh/boundary file:
//      - loosen matchTolerance of all cyclics to get case to load
//      - or change patch type from 'cyclic' to 'patch'
//        and regenerate cyclic as above
// Do a synchronisation of coupled points after creation of any patches.
// Note: this does not work with points that are on multiple coupled patches
//       with transformations (i.e. cyclics).
pointSync false;
patches
        name c1;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  c2;
             rotationAxis (0 1 0);
            // on bad meshes
            matchTolerance 0.1;
        patches (t1);
        name c2;
        patchInfo
            type            cyclicAMI;
            neighbourPatch  c1;
            // on bad meshes
            matchTolerance 0.1;
        patches (t2);
I used the transform/rotational options because I was meshing a quarter of a cylinder -- they may not be necessary.
Caelan
clapointe is offline   Reply With Quote
Understanding the cyclic boundary condition leroyv OpenFOAM Running, Solving & CFD 10 May 31, 2020 10:05
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
[mesh manipulation] CreatePatch to create cyclic boundary sbence OpenFOAM Meshing & Mesh Conversion 18 August 30, 2012 07:51
Cyclic Boundary Condition Asgarian OpenFOAM Running, Solving & CFD 3 December 29, 2011 20:45
cyclic boundary condition doesn't work in a tube ?? Cyp OpenFOAM 6 April 16, 2010 16:21
