mapFields error: Plane normal defined with zero length
Like Tree1Likes
  • 1 Post By LuckyTran
Old   August 13, 2015, 13:42
Default mapFields error: Plane normal defined with zero length
Gerd Fade
schiffbauer is on a distinguished road
Dear Foamers,
mapping a field with OF 2.4.0, I get the following error:
Create databases as time
Case   : ../testMap
nProcs : 1
Source time: 0
Target time: 0
Create meshes
Source mesh size: 36509    Target mesh size: 36509
Consistently creating and mapping fields for time 0
Creating mesh-to-mesh addressing for region0 and region0 regions using cellVolumeWeight
--> FOAM FATAL ERROR:
Bad points:(0.18 0.0839999 0.012) (0.18 0.0899998 0.012) (0.18 0.0959993 0.012)
    From function void plane::calcPntAndVec
    const point&,
    const point&,
    const point&
    in file meshes/primitiveShapes/plane/plane.C at line 116.
FOAM aborting
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::error::abort() at ??:?
#2  Foam::plane::calcPntAndVec(Foam::Vector<double> const&, Foam::Vector<double> const&, Foam::Vector<double> const&) at ??:?
#3  Foam::tetOverlapVolume::tetTetOverlapVol(Foam::tetPoints const&, Foam::tetPoints const&) const at ??:?
#4  Foam::tetOverlapVolume::cellCellOverlapVolumeMinDecomp(Foam::primitiveMesh const&, int, Foam::primitiveMesh const&, int, Foam::treeBoundBox const&) const at ??:?
#5  Foam::meshToMeshMethod::interVol(int, int) const at ??:?
#6  Foam::cellVolumeWeightMethod::calculateAddressing(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, int, int, Foam::List<int> const&, Foam::List<bool>&, int&) at ??:?
#7  Foam::cellVolumeWeightMethod::calculate(Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&, Foam::List<Foam::List<int> >&, Foam::List<Foam::List<double> >&) at ??:?
#8  Foam::meshToMesh::calcAddressing(Foam::word const&, Foam::polyMesh const&, Foam::polyMesh const&) at ??:?
#9  Foam::meshToMesh::calculate(Foam::word const&) at ??:?
#10  Foam::meshToMesh::constructNoCuttingPatches(Foam::word const&, Foam::word const&, bool) at ??:?
#11  Foam::meshToMesh::meshToMesh(Foam::polyMesh const&, Foam::polyMesh const&, Foam::meshToMesh::interpolationMethod const&, bool) at ??:?
#12  ? at ??:?
#13  ? at ??:?
#14  __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#15  ? at ??:?
Aborted (core dumped)
The mesh is a NACA profile in .stl-format, created with sHM.
Trying to find a solution, I did the following:
1.) run the simulation - OK
2.) copied the case folder and deleted the time directories
3.) run
mapFields ../sourceCase/
- NOT OK
Besides, I changed the mesh in the source case. The result was the same with the difference that the
Bad points: (...) ...
changed.
The other thread linked to this error didn't provide a solution. Do you have an idea?
schiffbauer is offline   Reply With Quote
Old   September 1, 2015, 05:23
Default not solved
Gerd Fade
I still have the same problem, does somebody has an idea?
Old   September 1, 2015, 16:54
Retired Super Moderator
Bruno Santos
Greetings schiffbauer,
I've searched with Google just now for:
site:www.cfd-online.com openfoam Plane normal defined with zero length
And quickly found this thread: http://www.cfd-online.com/Forums/ope...pfields-2.html - where in post #32 is the answer.
In addition to this, in OpenFOAM-dev, mapFields from 2.2 was restored and the one from 2.3 was renamed to mapFieldsPar: http://www.openfoam.org/mantisbt/view.php?id=1702
Best regards,
Bruno
Old   September 2, 2015, 03:43
Default Thanks
Gerd Fade
Thanks for your quick answer.
Well, actually I wanted to solve it with the actual OF version 2.4.0, but this might be not the easiest way...
Old   July 19, 2016, 06:46
danielbanos10's Avatar
danielbanos10 is on a distinguished road
I had the same error in OF 2.4, and the solution I found was to move the target mesh a little bit into the soure mesh, in orden to use cuttingPatches instead of patchMap.
And now it works, and there is no normal errors.
Best regards
danielbanos10 is offline   Reply With Quote
Old   April 26, 2018, 18:02
Lucky
I followed the suggestion in #34 and added
-mapMethod mapNearest
the default is cellVolumeWeight. Using mapNearest successfully mapped.
ssa_cfd likes this.
Old   April 10, 2023, 16:23
Default tried mapNearest, but causes a problem
Alan w
boffin5 is on a distinguished road
For the run error of "plane nomal defined with zero length", I tried the suggestion of using "mapNearest" in fvOptions.
I have two simulations that I tried it on; the first was a chtMultiRegion case with complicated geometry which takes a long time to mesh. Using mapNearest, the simulation locked up in the chtMultiRegionFoam phase.
So I then went to a simple template case with the same setup. This one runs quickly, so is good to try things on. However, when I used mapNearest, it simply caused the simulation to lock up just as with the complicated case.
Am I missing something? Maybe a tolerance setting?
boffin5 is offline   Reply With Quote
[ICEM] How can I define different zones in ICEM? llrr ANSYS Meshing & Geometry 14 February 12, 2017 14:44
UDF to Access Wall Normal Concentration Gradient Daniel Tanner Fluent UDF and Scheme Programming 4 February 18, 2015 15:35
OpenFOAM static build on Cray XT5 asaijo OpenFOAM Installation 9 April 6, 2011 13:21
OpenFOAM13 for Mac OSX Darwin 104 hjasak OpenFOAM Installation 70 September 24, 2010 06:06
DPM: Particle Tracking Madhukar FLUENT 1 July 24, 2007 04:51
