how to use chemkinToFoam ?
Like Tree2Likes
  • 2 Post By stack
Old   July 5, 2015, 19:12
Default how to use chemkinToFoam ?
khalifa is on a distinguished road
Hello. can someone explain a bit how to use chemkinToFoam to convert the GRI-3 mechanism files; both reactions and thermodynamics file, from chemkin 2 format to the openFoam format ?
Thanks
khalifa is offline   Reply With Quote
Old   July 29, 2015, 20:08
stack is on a distinguished road
Working through this issue myself.
Download grimech30.dat and thermo30.dat: http://combustion.berkeley.edu/gri-m...30/text30.html
Running below should output the files you want (had to remove line #2 in thermo30.dat.)
chemkinToFoam -newFormat grimech30.dat thermo30.dat chem thermo
Uyan and khalifa like this.
stack is offline   Reply With Quote
Old   August 20, 2015, 17:34
Thank you so much ! worked perfectly.
Old   August 26, 2015, 18:17
Dear Stack,
Do you know how to transfer the transport file from chemkin to Foam ? , chemkintofoam utility allows me only to transfer the reaction and thermodynamics files!
Thank you
Old   July 16, 2022, 06:38
Default chemkinToFoam
Elhaddad
AhmedSamy is on a distinguished road
I tried the following command using both versions Openfoam 8 and 2112, which did not work
I get this error:
--> FOAM FATAL IO ERROR: (openfoam-2112)
"ill defined primitiveEntry starting at keyword 'THERMO' on line 1 and ending at line 4"
file: therm.dat at line 4.
From void Foam:rimitiveEntry::readEntry(const Foam::dictionary&, Foam::Istream&)
in file db/dictionary/primitiveEntry/primitiveEntryIO.C at line 238.
Any help is appreciated.
Thank's
AhmedSamy is offline   Reply With Quote
Chemkin reader stefanke OpenFOAM Pre-Processing 28 March 8, 2022 11:16
about chemkintofoam dahlia-2005 OpenFOAM 24 February 19, 2017 04:10
how to use chemkinToFoam ? khalifa OpenFOAM Running, Solving & CFD 1 July 4, 2015 06:09
question about chemkinToFoam skarnani OpenFOAM 11 September 11, 2013 09:07
