Issues with splitMeshRegions!
Like Tree1Likes
  • 1 Post By vabishek
Old   July 2, 2015, 15:01
Unhappy Issues with splitMeshRegions!
VA
vabishek is on a distinguished road
Hello FOAMers,
I am currently working on a chtMultiRegionSimpleFoam problem. I am having issues with creating multiple regions using splitMeshRegions command. The geometry is fairly simple. The computational domain consists of a fluid region and multiple solid regions, as shown in the image (attached). The fluid flows through a rectangular channel (FLUID_CHANNEL) surrounded by solid regions (PLATE1, SOLID1, HEAT_GEN, PLATE2). A heat source is applied to the "heat generation" region, and each of the regions have different material properties.
The geometry is meshed in SALOME and imported into OpenFOAM using the ideasUnvToFoam tool. Everything seems to work fine until I run splitMeshRegions. When I run splitMeshRegions, it creates 6 regions instead of 5 (Fluid_channel, Plate1, Heat_gen, Plate2 and Solid). The heat_gen region is split into two i.e. heat_gen and some domain*. As seen in the attached image, the heat_gen region consists of two blocks separated by the fluid_channel. I am not sure why splitMeshRegions does that.
I also tried an alternative way of defining the regions. I created the domain with only four regions (all same as above except Heat_gen), then used topoSet to create the Heat_gen region. Worked fine till here. However, when I ran splitMeshRegions it again split heat_gen into two regions instead of just one.
I have attached the case files for both the scenarios i.e. with and without heat_gen in the mesh file. Any help on this would be greatly appreciated. Please let me know if more information is needed.
https://www.dropbox.com/sh/ehdiebogz...BcxPIf95a?dl=0
Thanks,
Abishek
PS: I tried one other method. Since the geometry is simple, I used blockMesh to create the geometry. The splitMeshRegions worked fine in this case. Puzzled as to why I am getting different results. I need to use SALOME as I will be moving much more complex geometries than a huge rectangular block.
vabishek is offline   Reply With Quote
Old   July 3, 2015, 05:43
Ohlzen-Wendy is on a distinguished road
are the regions of the heater connected or os there a gap? I think this might be the problem. i had an similar issue were a had to regions wich had the some properties etc but were not connected. splitmeshregion then created 2 regions out of it. maybe name it heater1 and heater2.
with regards
andy
Ohlzen-Wendy is offline   Reply With Quote
Old   July 3, 2015, 11:55
VA
Originally Posted by Ohlzen-Wendy View Post
with regards
andy
Thanks for your reply!
Yes, these two regions are not connected. I could easily have two regions as heater1 and heater2. I can't do that as I need to use cyclic boundaries on the side walls. Forgot to mention that. So, I when split into two separate regions it is obviously not recognizing the neighbourPatch as that belongs in a different region now. I was able to circumvent this issue when I used blockMesh-topoSet-splitMeshRegions. I defined two boxes (region) as a single region in topoSet (while creating sets). Can't seem to achieve the same using mesh import-topoSet-splitMeshRegions.
Thanks!
Old   July 6, 2015, 09:41
VA
Any comments/suggestions please?
Old   July 6, 2015, 11:27
VA
I solved the issue. I was using "splitMeshRegions -cellZones" all this while. I tried "splitMeshRegions -cellZonesOnly", as I wanted the zones to be created based on my mesh,and it works perfectly. The -help option came in handy.
Thanks!
aero.rajat1 likes this.
Old   July 24, 2018, 20:11
charles4allme is on a distinguished road
I don't know how best to frame the question, but essentially I imported a mesh from salome and while trying to use toposet, I can't get all the regions in OpenFOAM when I input values for the box in toposet. Is the axis of SALOME different from that of OPenFOAM or is it a problem of SI units.Any advice will be greatly appreciated.
charles4allme is offline   Reply With Quote
Old   October 25, 2018, 14:16
Murilo Mendonça
murilommen is on a distinguished road
Could you find a solution for this Charles? I am facing the same problem with a mesh imported from ANSYS. topoSet runs but creates a cellSet with dimension 0.
murilommen is offline   Reply With Quote
chtmultiregionfoam, splitmeshregions
[mesh manipulation] why splitMeshRegions creates extra domains? skuznet OpenFOAM Meshing & Mesh Conversion 10 May 31, 2022 06:54
Multigrid Stability Issues ThomasHermann SU2 1 November 5, 2014 17:18
splitMeshRegions doesn't find my regions. GPesch OpenFOAM Pre-Processing 2 November 14, 2013 06:20
[General] Issues with output to VTK format akail ParaView 0 February 19, 2013 15:38
[General] Some Paraview Issues I can not solve MR_Chicho ParaView 1 September 24, 2012 06:03
