pressure inlet conditions for unknown pressure
Like Tree2Likes
  • 2 Post By alexB
Old   June 15, 2015, 12:18
Default pressure inlet conditions for unknown pressure
mike
dEntropy is on a distinguished road
hi,
me = noob
me = that guy who has spent days searching
me = that guy who prefers comsol over openFoam
preliminaries: i'm trying to solve an incompressible flow problem with a simple Newtonian fluid. I am using a fairly simple geometry, though the fluid dynamics are anything but simple. I know the Re, so i am setting the inlet as a uniform fixed value and trying to get output from potentialFoam...for use in my pimpleFoam simulation.
I do not know the pressure, but i can at least set the outlet as a uniform fixed value = 0, or zerogradient.
I have absolutely no idea what value to set for pressure inlet. None!
ideas?
p:
FoamFile
    version     2.0;
    format      ascii;
    class       volScalarField;
    object      p;
dimensions      [1 -1 -2 0 0 0 0];
internalField   uniform 0;
boundaryField
    inlet-1
        type            zeroGradient;
    inlet-2
        type            zeroGradient;
    outlet-1
        type            zeroGradient;
    outlet-2
        type            zeroGradient;
    walls
        type            fixedValue;
        value           uniform 0;
U:
FoamFile
    version     2.0;
    format      ascii;
    class       volVectorField;
    object      U;
dimensions      [0 1 -1 0 0 0 0];
internalField   uniform (0 0 0);
boundaryField
    outlet-1
        type            zeroGradient;
    outlet-2
        type            zeroGradient;
    inlet-1
        type            uniformFixedValue;
        uniformValue    constant (1 0 0);
    inlet-2
    walls
        type            fixedValue;
        value           uniform (0 0 0);
dEntropy is offline   Reply With Quote
Old   July 5, 2015, 01:38
Ashwani
AshwaniAssam is on a distinguished road
What happens you use these boundary conditions. I mean to say as per the p file, you are using zero gradient for the pressure do you get the result with this. It should be working.
AshwaniAssam is offline   Reply With Quote
Old   July 5, 2015, 20:43
mike
i've since set the pressure outlet to fixed value = 0.
i think the solvers and schemes are equally as important, and i've recently found ones that work well.
Old   July 6, 2015, 08:15
Alexander Bartel
alexB is on a distinguished road
Hi mike,
perhaps pressureInletOutletVelocity ( http://cfd.direct/openfoam/user-guide/boundaries/ ) would fit to your problem but I don't know what you are planning with the inlet and outlet.
Perhaps you should look which tutorial ( http://www.rapidof.com/wp-content/up...rialsGuide.pdf ) could fit to your problem best and adapt it for your needs.
regards
Alex
student666 and AshwaniAssam like this.
Please note that I do not use the Friend-feature, so do not be offended, if I do not accept a request.
alexB is offline   Reply With Quote
Old   July 15, 2015, 11:52
mike
hi Alex,
so, I've just set the pressure inlets as zeroGradient boundaries and the outlets as fixed value = 0.
i was using the velocity inlets as surfaceNormalFixedValue and the velocity outlets as zeroGradients.
i have since been working towards explicitly solving for the square duct velocity profile and applying that as the inlet condition. otherwise, i need to run potentialFoam or my actual pisoFoam run with long inlet channels before I get a fully developed profile.
Old   July 15, 2015, 17:27
Alexander Bartel
Hi mike,
I am not that much in potentialFOAM, pisoFOAM and the corresponding boundary conditions.
I hope someone else could help you better.
regards
Alex
Pressure inlet boundary conditions for open channel flows jack2000 OpenFOAM Running, Solving & CFD 5 December 6, 2018 12:00
2D Hypersonic Inlet in FLUENT - Convergence Issues Fraisdegout FLUENT 6 December 15, 2016 03:07
CFX Simple valve model, inlet and outlet conditions 749604 CFX 24 August 11, 2014 19:51
UDF to set velocity and pressure in inlet GerardX89 Fluent UDF and Scheme Programming 0 July 16, 2012 11:15
pressure with velocity inlet boundary conditions Ashraf Sharara FLUENT 1 August 21, 2008 08:29
