Using the mapFields utility
Like Tree1Likes
  • 1 Post By sweisenb
Old   May 14, 2015, 14:47
Default Using the mapFields utility
Sofy
sweisenb is on a distinguished road
I am running OpenFOAM 2.3.1 in an Ubuntu Linux operating system.
I have run a simulation in simpleFoam and would like to run it several more times in a very similar way. It took approx. 20,000 iterations to converge, so I would like to set up a smart initial field to get a more quickly converging solution in the next runs. I was told that mapFields is a good utility to do this.
However, I am new to OpenFOAM and Linux/programming, so I don't understand what I have to type to get the mapping to be applied from my source directory (which I am guessing would be the "time" directory in my converged solution with which I want to set up the new initial field in my next runs) to the target directory (which would be the "0" time step of the next run??).
I saw this line: mapFields*<source*dir>*-consistent
But can someone really spell this out to me with an example, like type the source and target directory names and everything? I just want to know exactly what I have to write in the Ubuntu terminal to make the transfer successful.
Also, is there anything else to do for setting up the problem in the 0 directory, controlDict, etc. to make it start from the new initial field and not from the original given boundary conditions?
Thank you very much for your assistance!
Sofy
Nostradamus likes this.
sweisenb is offline   Reply With Quote
Old   May 14, 2015, 15:06
Wouter van der Meer
wouter is on a distinguished road
hello Sofy,
In the userguide in doc/guides-a4 page U-31 the cavity tutoral mapfields is explained
Hope this helps
Wouter
wouter is offline   Reply With Quote
Old   May 18, 2015, 16:54
Sofy
Thank you Wouter,
So from reading, I understand that the actual command line is executed from within the target directory, and the command includes a reference to the source directory. Is this right?
Thank you,
Sofy
mapfields
Something doens't work with wallHeatFlux utility or externalWallHeatFluxTemperat BC!! zfaraday OpenFOAM Post-Processing 0 February 5, 2015 17:47
Difficulty with mapFields utility rnburne OpenFOAM Pre-Processing 0 June 2, 2014 17:33
The -parallel parameter of mapFields utility in OpenFOAM v2.3.0 shuoxue OpenFOAM Pre-Processing 1 April 28, 2014 06:59
mapFields utility openfoammaofnepo OpenFOAM 2 June 29, 2013 17:55
mapFields utility cristobal OpenFOAM 1 April 1, 2010 12:09
