March 29, 2015, 12:18 |
mapFields taking too long
Rep Power: 14 |
Hi foamers,
I am facing a problem of mapFields taking too long to map fields from a fine mesh to a coarser mesh. I am running simulation using sprayFoam, and want to coarse the mesh to achieve faster solution. So I executed: Code:
mpirun -n 4 mapFields ../aachenBomb-fine -sourceTime latestTime -consistent -parallel Code:
Create meshes Source mesh size: 42025 Target mesh size: 42025 Consistently creating and mapping fields for time 0.0004 Creating mesh-to-mesh addressing for region0 and region0 regions using cellVolumeWeight Overlap volume: 4e-05 Creating AMI between source patch walls and target patch walls using faceAreaWeightAMI AMI: Creating addressing and weights between 19762 source faces and 19762 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 1, 1 interpolating mut interpolating rho interpolating PaSR:kappa interpolating k interpolating H2O interpolating PaSR:dQ interpolating alphat interpolating N2 interpolating O2 interpolating dQ interpolating p interpolating T interpolating epsilon interpolating U processing cloud "sprayCloud" kind regards, carlen PS: I am using OF2.3.1 Last edited by wyldckat; March 29, 2015 at 13:02. Reason: merged posts that were 2 minutes apart and added [CODE][/CODE] |
March 29, 2015, 13:04 |
#2 | |
Retired Super Moderator
Bruno Santos
Rep Power: 128 |
Quick answer: http://www.openfoam.org/mantisbt/view.php?id=1326#c3694
March 29, 2015, 21:50 |
Rep Power: 14 |
Hi Bruno,
Thank you for kindly moving my thread to an appropriate section. I will try the direct method and let you know if the execution time is reduced. Best regards, carlen |
March 29, 2015, 22:38 |
Rep Power: 14 |
Hi bruno,
I have tried using direct mapMethod and now it gets to this state much faster (2s): Code:
Source time: 0.0004 Target time: 0 Create meshes Source mesh size: 42025 Target mesh size: 42025 Consistently creating and mapping fields for time 0.0004 Creating mesh-to-mesh addressing for region0 and region0 regions using direct Overlap volume: 4e-05 Creating AMI between source patch walls and target patch walls using directAMI AMI: Creating addressing and weights between 19762 source faces and 19762 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 2, 1.0022 interpolating mut interpolating rho interpolating PaSR:kappa interpolating k interpolating H2O interpolating PaSR:dQ interpolating alphat interpolating N2 interpolating O2 interpolating dQ interpolating p interpolating T interpolating epsilon interpolating U processing cloud "sprayCloud" Code:
mpirun -n 4 mapFields ../aachenBomb-twoparcels -mapMethod direct -sourceTime latestTime -consistent -parallel Code:
mpirun -n 4 mapFields ../aachenBomb-twoparcels -mapMethod direct -consistent -parallel Code:
processing cloud "sprayCloud" How can I solve this problem? |
March 30, 2015, 00:47 |
Rep Power: 14 |
Hi everyone,
I think I found a solution for this problem, I now type in Code:
mpirun -n 4 mapFields ../aachenBomb-twoparcels -mapMethod direct -sourceTime latestTime -consistent -noLagrangian -parallel Code:
Source time: 0.0004 Target time: 0 Create meshes Source mesh size: 42025 Target mesh size: 42025 Consistently creating and mapping fields for time 0.0004 Creating mesh-to-mesh addressing for region0 and region0 regions using direct Overlap volume: 4e-05 Creating AMI between source patch walls and target patch walls using directAMI AMI: Creating addressing and weights between 19762 source faces and 19762 target faces AMI: Patch source sum(weights) min/max/average = 1, 1, 1 AMI: Patch target sum(weights) min/max/average = 1, 2, 1.0022 interpolating mut interpolating rho interpolating PaSR:kappa interpolating k interpolating H2O interpolating PaSR:dQ interpolating alphat interpolating N2 interpolating O2 interpolating dQ interpolating p interpolating T interpolating epsilon interpolating U End Finalising parallel run Cheers, |
March 30, 2015, 01:18 |
Rep Power: 14 |
Carlen again,
I found that it is problematic to run simulation for the mapped case without mapping the lagrangian fields. it gives so many errors that I cannot find a solution for. Code:
[[A[carlen@localhost aachenBomb-mapFields]$ mpirun -carlenSprayFoam -parallel /*---------------------------------------------------------------------------*\ | ========= | | | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox | | \\ / O peration | Version: 2.3.1 | | \\ / A nd | Web: www.OpenFOAM.org | | \\/ M anipulation | | \*---------------------------------------------------------------------------*/ Build : 2.3.1-262087cdf8db Exec : carlenSprayFoam -parallel Date : Mar 30 2015 Time : 15:14:11 Host : "localhost.localdomain" PID : 13054 Case : /home/carlen/OpenFOAM/carlen-2.3.1/carlenVOFLPT/run/aachenBomb-mapFields nProcs : 4 Slaves : 3 ( "localhost.localdomain.13055" "localhost.localdomain.13056" "localhost.localdomain.13057" ) Pstream initialized with: floatTransfer : 0 nProcsSimpleSum : 0 commsType : nonBlocking polling iterations : 0 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 Reading g Creating combustion model Selecting combustion model PaSR<psiChemistryCombustion> Selecting chemistry type { chemistrySolver ode; chemistryThermo psi; } Selecting thermodynamics package { type hePsiThermo; mixture reactingMixture; transport sutherland; thermo janaf; energy sensibleEnthalpy; equationOfState perfectGas; specie specie; } Selecting chemistryReader chemkinReader Reading CHEMKIN thermo data in new file format [2] #0 Foam::error::printStack(Foam::Ostream&)[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:? [2] #1 Foam::sigFpe::sigHandler(int) at ??:? [0] #1 Foam::sigFpe::sigHandler(int) at ??:? [2] #2 at ??:? [0] #2 [2] at sigaction.c:? [2] #3 double Foam::max<Foam::fvPatchField, double>(Foam::FieldField<Foam::fvPatchField, double> const&)[0] at sigaction.c:? [0] #3 at ??:? [2] #4 double Foam::max<Foam::fvPatchField, double>(Foam::FieldField<Foam::fvPatchField, double> const&)Foam::dimensioned<double> Foam::max<double, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [0] #4 at ??:? [2] #5 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::correctMassFractions()Foam::dimensioned<double> Foam::max<double, Foam::fvPatchField, Foam::volMesh>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:? [2] #6 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::multiComponentMixture(Foam::dictionary const&, Foam::List<Foam::word> const&, Foam::HashPtrTable<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >, Foam::word, Foam::string::hash> const&, Foam::fvMesh const&) at ??:? [0] #5 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::correctMassFractions() at ??:? [2] #7 Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::reactingMixture(Foam::dictionary const&, Foam::fvMesh const&) at ??:? [0] #6 Foam::multiComponentMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::multiComponentMixture(Foam::dictionary const&, Foam::List<Foam::word> const&, Foam::HashPtrTable<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> >, Foam::word, Foam::string::hash> const&, Foam::fvMesh const&) at ??:? [2] #8 Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? [0] #7 Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::reactingMixture(Foam::dictionary const&, Foam::fvMesh const&) at ??:? [2] #9 Foam::psiReactionThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? [0] #8 Foam::heThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::heThermo(Foam::fvMesh const&, Foam::word const&) at ??:? [2] #10 Foam::autoPtr<Foam::psiReactionThermo> Foam::basicThermo::New<Foam::psiReactionThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? [0] #9 Foam::psiReactionThermo::addfvMeshConstructorToTable<Foam::hePsiThermo<Foam::psiReactionThermo, Foam::SpecieMixture<Foam::reactingMixture<Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > > >::New(Foam::fvMesh const&, Foam::word const&) at ??:? [2] #11 Foam::psiReactionThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? [0] #10 Foam::autoPtr<Foam::psiReactionThermo> Foam::basicThermo::New<Foam::psiReactionThermo>(Foam::fvMesh const&, Foam::word const&) at ??:? [2] #12 Foam::psiChemistryModel::psiChemistryModel(Foam::fvMesh const&) at ??:? [0] #11 Foam::psiReactionThermo::New(Foam::fvMesh const&, Foam::word const&) at ??:? [2] #13 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::chemistryModel(Foam::fvMesh const&) at ??:? [2] #14 Foam::ode<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::ode(Foam::fvMesh const&) at ??:? [0] #12 Foam::psiChemistryModel::psiChemistryModel(Foam::fvMesh const&) at ??:? [2] #15 Foam::psiChemistryModel::addfvMeshConstructorToTable<Foam::ode<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&) at ??:? [0] #13 Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > >::chemistryModel(Foam::fvMesh const&) at ??:? [2] #16 Foam::autoPtr<Foam::psiChemistryModel> Foam::basicChemistryModel::New<Foam::psiChemistryModel>(Foam::fvMesh const&) at ??:? [0] #14 Foam::ode<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > >::ode(Foam::fvMesh const&) at ??:? [2] #17 Foam::psiChemistryModel::New(Foam::fvMesh const&) at ??:? [0] #15 Foam::psiChemistryModel::addfvMeshConstructorToTable<Foam::ode<Foam::chemistryModel<Foam::psiChemistryModel, Foam::sutherlandTransport<Foam::species::thermo<Foam::janafThermo<Foam::perfectGas<Foam::specie> >, Foam::sensibleEnthalpy> > > > >::New(Foam::fvMesh const&) at ??:? [2] #18 Foam::combustionModels::psiChemistryCombustion::psiChemistryCombustion(Foam::word const&, Foam::fvMesh const&) at ??:? [0] #16 Foam::autoPtr<Foam::psiChemistryModel> Foam::basicChemistryModel::New<Foam::psiChemistryModel>(Foam::fvMesh const&) at ??:? [2] #19 Foam::combustionModels::laminar<Foam::combustionModels::psiChemistryCombustion>::laminar(Foam::word const&, Foam::fvMesh const&) at ??:? [0] #17 Foam::psiChemistryModel::New(Foam::fvMesh const&) at ??:? [2] #20 Foam::combustionModels::PaSR<Foam::combustionModels::psiChemistryCombustion>::PaSR(Foam::word const&, Foam::fvMesh const&) at ??:? [2] #21 Foam::combustionModels::psiCombustionModel::adddictionaryConstructorToTable<Foam::combustionModels::PaSR<Foam::combustionModels::psiChemistryCombustion> >::New(Foam::word const&, Foam::fvMesh const&) at ??:? [0] #18 Foam::combustionModels::psiChemistryCombustion::psiChemistryCombustion(Foam::word const&, Foam::fvMesh const&) at ??:? [2] #22 Foam::combustionModels::psiCombustionModel::New(Foam::fvMesh const&) at ??:? [0] #19 Foam::combustionModels::laminar<Foam::combustionModels::psiChemistryCombustion>::laminar(Foam::word const&, Foam::fvMesh const&) at ??:? [2] #23 at ??:? [0] #20 Foam::combustionModels::PaSR<Foam::combustionModels::psiChemistryCombustion>::PaSR(Foam::word const&, Foam::fvMesh const&) at ??:? [0] #21 Foam::combustionModels::psiCombustionModel::adddictionaryConstructorToTable<Foam::combustionModels::PaSR<Foam::combustionModels::psiChemistryCombustion> >::New(Foam::word const&, Foam::fvMesh const&) at ??:? [0] #22 Foam::combustionModels::psiCombustionModel::New(Foam::fvMesh const&)[2] at ??:? [2] #24 __libc_start_main at ??:? [2] #25 at ??:? [0] #23 [2] at ??:? [localhost:13056] *** Process received signal *** [localhost:13056] Signal: Floating point exception (8) [localhost:13056] Signal code: (-6) [localhost:13056] Failing at address: 0x1f400003300 [localhost:13056] [ 0] /lib64/libc.so.6[0x3621c326a0] [localhost:13056] [ 1] /lib64/libc.so.6(gsignal+0x35)[0x3621c32625] [localhost:13056] [ 2] /lib64/libc.so.6[0x3621c326a0] [localhost:13056] [ 3] carlenSprayFoam(_ZN4Foam3maxINS_12fvPatchFieldEdEET0_RKNS_10FieldFieldIT_S2_EE+0xdc)[0x449b5c] [localhost:13056] [ 4] [localhost:13054] [23] carlenSprayFoam[0x42dffa] [localhost:13054] [24] /lib64/libc.so.6(__libc_start_main+0xfd)[0x3621c1ed5d] [localhost:13054] [25] carlenSprayFoam[0x4338e5] [localhost:13054] *** End of error message *** [localhost:13057] *** An error occurred in MPI_Pack [localhost:13057] *** reported by process [140187236761601,140733193388035] [localhost:13057] *** on a NULL communicator [localhost:13057] *** Unknown error [localhost:13057] *** MPI_ERRORS_ARE_FATAL (processes in this communicator will now abort, [localhost:13057] *** and potentially your MPI job) -------------------------------------------------------------------------- mpirun noticed that process rank 0 with PID 13054 on node localhost exited on signal 8 (Floating point exception). -------------------------------------------------------------------------- |
March 30, 2015, 01:30 |
Rep Power: 14 |
Hi everyone,
its carlen again. It is hilarious I have been talking to myself and get the solution by myself . Anyway, I figured out how to solve the problem. By looking into the 0 folder, I realise that only T, p, U fields are needed for such a simulation. So I type in: Code:
mpirun -n 4 mapFields ../aachenBomb-twoparcels -mapMethod direct -sourceTime latestTime -fields '(U T p)' -consistent -noLagrangian -parallel Cheers, Carlen |
March 30, 2015, 01:53 |
Rep Power: 14 |
Now you can see the pressure field is identical for both the source and target case!
March 30, 2015, 06:19 |
#9 |
Rep Power: 14 |
it turns out that I have to use
-mapMethod cellVolumeWeight carlen |
April 4, 2015, 14:44 |
#10 |
Bruno Santos
Rep Power: 128 |
Hi Carlen,
Many thanks for sharing each step you've done! As for a faster method, have you tried using "-mapMethod mapNearest"? It should be faster, although it will strongly depend on how related the fine mesh is to the coarse mesh, i.e. if the fine mesh is simply the coarse refined for some or all cells in a 2x2x2 division for each cell. Best regards, Bruno |
Problem with pow and volScalarField | _Stefan_ | OpenFOAM Programming & Development | 15 | April 14, 2019 23:20 |
Transient Simulation Taking Very Long TIME!!!! Help | 88phil88 | CFX | 17 | November 3, 2017 05:07 |
Transient run taking too long time | Alexander Tham Keat Fu | CFX | 3 | June 20, 2012 07:53 |
OpenFOAM-1.5-dev svn revision 1438: libOpenFOAM does not compile in SP | 4xF | OpenFOAM Bugs | 3 | October 16, 2009 06:35 |
Missing math.h header | Travis | FLUENT | 4 | January 15, 2009 12:48 |
