groovyFlowRateInletVelocity
Like Tree2Likes
  • 2 Post By mgdenno
Old   January 29, 2015, 07:49
Question groovyFlowRateInletVelocity
Pratik Nanavati
nanavati is on a distinguished road
Hello All,
How do I change mass flow rates at inlet, only for a certain timesteps ?
for example, as of now my inlet U patch is,
Inlet
type flowRateInletVelocity;
massFlowRate constant 0.00195277; //= 7 kg/h
rhoInlet 1.188;
value uniform (1 0 0);
where as you can see Mass flow of Air is 7 kg/h (0.00195277 kg/sec)
now what I want to do is,
I want to change this mass flow from 7 to 5 kg/hr, only for a period of 2 seconds. then back to 7 kg/hr.
(simulation controlDict; startTime is 0 sec and endTime is 10 sec)
I guess this can be done by groovyBC, but i have no idea how to change the boundary condition and its expressions.
nanavati is offline   Reply With Quote
Old   January 29, 2015, 20:11
Matthew Denno
mgdenno is on a distinguished road
Try this http://www.openfoam.org/version2.1.0...conditions.php
nanavati and Tom123 like this.
mgdenno is offline   Reply With Quote
Old   January 30, 2015, 05:10
Pratik Nanavati
Originally Posted by mgdenno View Post
Thanks for the quick suggestion.. It works like a charm !
Old   January 30, 2015, 05:17
Pratik Nanavati
I modified my Inlet BC as,
Inlet
massFlowRate tableFile;
rhoInlet 1.188;
tableFileCoeffs
fileName "$FOAM_CASE/ramp"
outOfBounds clamp;
and in my Case folder I made on file named ramp
which contains,
(0 0.001952)
(7 0.001952) // from 0 to 7 miliseconds, constant flow
(8 0.003888) // from 7 to 8 miliseconds, increase in flow
(9 0.001952) // from 8 to 9 miliseconds, decreasing it again to initial value
flowrateinletvelocity, groovybc, swak4foam
