How can I calculate Nusselt number in this problem
Like Tree1Likes
  • 1 Post By ranasa
Old   October 2, 2014, 17:20
Default How can I calculate Nusselt number in this problem
sajad
sajad6 is on a distinguished road
hi
I want to solve a free sream over 2 block and the condition is steady and laminar and the fluid is incompressible.the problem's picture is attached below.
My porpuse is to calculate Nusselt number of 2 blocks in boundry of fluid.
the tempereture of blocks is constant and is equal to 60 'c.
which solver is better for my problem?how can I use this solver for my porpuse in order to calculate Nusselt number.
sajad6 is offline   Reply With Quote
Old   October 4, 2014, 06:03
Nima Samkhaniani
nimasam is on a distinguished road
well Dear Sajad
you can use bouyantBoussinqSimpleFoam for simulation.
for calculation of Nusselt Number you can use swak4Foam
or look for written codes in forum
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   February 5, 2016, 09:42
rana
ranasa is on a distinguished road
Hi dear friends
I'm gonna simulate a 3D buoyancy driven flow over a cylinder and want to calculate nusselt number over this patch (i mean cylinder)
i use swak4foam and added these expressions to the end of controlDict file,
lib
"libFVFunctionObjects.so"
function
NusseltNumber
functionObjectLibs
//"libsimpleFunctionObjects.so"
"libsimpleSwakFunctionObjects.so"
type patchExpression;
outputControlMode timeStep;
outputInterval 1;
patches
cyl
verbose true;
variables
"T_inf=300;"
"D=0.00762;"
expression "D*snGrad(T)/(T-T_inf)";
accumulations
average
log true;
it begins running without any error. The question is here, how can i see the results for nusselt number? should i enter some commands in terminal while iterating or wait until the solution is over?
looking forward to your helpful comments
thanks
student666 likes this.
ranasa is offline   Reply With Quote
Old   February 5, 2016, 14:38
Nima Samkhaniani
the average nusselt number is written in a file in the test case folder, you can see the result in excel software or plot it using gnuplot
Old   May 1, 2016, 15:58
Post nusselt number
narayana vekamulla
vnarayana is on a distinguished road
NusseltCalc code has done. I am using buoyantBoussinesqSimpleFoam. for post processing results
Do i need to change transportProperties/ControlDict file ?
functions
probes
type probes;
name probes;
functionObjectLibs ("libsampling.so");
probeLocations
(0.025627 0 -0.00023237)
(0.0518278 0 -0.000461021)
fields
NusseltNumber
mode magnitude;
outputControl outputTime;
outputInterval 1;
i could not get the results, if you have any idea please send the file. Thank you. Recently i started my work with OpenFOAM.
vnarayana is offline   Reply With Quote
Old   December 6, 2017, 15:21
Default nusselt number
Ali Mohammadi
cfd lover is on a distinguished road
i have calculated my nusselt number over a duct.
first you need to make changes in controldict and then define the relation to calculate the nusselt number.
Here is my files
File Type: gz system.tar.gz (840 Bytes, 71 views)
cfd lover is offline   Reply With Quote
there is a problem with fully developed Nusselt number eeman Fluent UDF and Scheme Programming 4 September 24, 2012 02:36
How to obtain average Nusselt number Caner Main CFD Forum 3 March 2, 2012 15:44
Nusselt Number jlx Main CFD Forum 2 January 14, 2011 14:30
need to calculate Nusselt Number OnuR CFX 1 January 11, 2010 02:50
how to calculate Nusselt number? prayskyer Main CFD Forum 0 June 17, 2006 21:57
