How to remove the part of geometry in STL file
Like Tree1Likes
  • 1 Post By jhoepken
Old   June 23, 2014, 02:20
Default How to remove the part of geometry in STL file
DongHo
eddykendo is on a distinguished road
Hi! Foamers
I have STL file in which a rotor and a fuselage are separated each other.
At this moment, I just want to simulate the flow fields around the fuselage, not rotor.
For this, I'd like to remove the rotor geometry in STL file.
How to remove the rotor using commands concerning STL file in OpenFOAM?
I will appreciate it if anybody can let me know how to do that.
Thanks
eddykendo is offline   Reply With Quote
Old   June 29, 2014, 04:24
Nima Samkhaniani
nimasam is on a distinguished road
well, i dont know how complicated your geometry is
but you can limit your blockMesh box to fuselage, then it would cut automatically
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   June 29, 2014, 04:42
Jens Höpken
jhoepken is on a distinguished road
Send a message via Skype™ to jhoepken
You can do it in paraview as well. Open the STL, clip at the desired position, apply the "Triangulate" filter and save as STL. This has to be repeated, for the inverted normal vector of the clipping plane.
Jens
nimasam likes this.
jhoepken is offline   Reply With Quote
Old   June 30, 2014, 03:59
DongHo
Hi
Thank you for your reply.
I have fixed a problem using "Clip"
Your suggestion could be the one to fix it, but when the distance between two parts is too close, it might be very difficult to remove one of them only by using blockMesh.
Thanks
Old   June 30, 2014, 04:05
DongHo
Hi Jens
As you mentioned, I have removed blades leaving a fuselage as itself using "clip" in paraview.
It was quite helpful for me.
Thanks
Old   June 30, 2014, 11:19
Jens Höpken
Originally Posted by eddykendo View Post
Hi Jens
Thanks
Thanks, I'm glad that I could help.
[swak4Foam] funkyDoCalc with OF2.3 massflow NiFl OpenFOAM Community Contributions 14 November 25, 2020 04:30
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 10:17
patch error OF v2.2.2 mac hewei OpenFOAM Installation 4 November 30, 2013 17:55
Trouble compiling utilities using source-built OpenFOAM Artur OpenFOAM Programming & Development 14 October 29, 2013 11:59
OpenFOAM on MinGW crosscompiler hosted on Linux allenzhao OpenFOAM Installation 127 January 30, 2009 20:08
