No "neighbourPatch" provided. Is your mesh uptodate with split cyclics? |
April 10, 2014, 05:59 |
Amin
Rep Power: 12 |
Hello OpenFOAM-Users
In order to assure the rotational symmerty, i am trying use the boundary condition "cyclic". but i am not able to run blockMesh and am getting this FOAM FATAL IO ERROR : Code:
Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM FATAL IO ERROR: No "neighbourPatch" provided. Is your mesh uptodate with split cyclics? Run foamUpgradeCyclics to convert mesh and fields to split cyclics. file: .front from line 201 to line 0. From function cyclicPolyPatch::cyclicPolyPatch ( const word& name, const dictionary& dict, const label index, const polyBoundaryMesh& bm ) in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 680. FOAM exiting Code:
FoamFile { version 2.0; format ascii; class dictionary; object blockMeshDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // General m4 macros // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // // User-defined parameters convertToMeters 0.001; // Alle Eingaben sind in mm // Parametric description vertices ( (0.332499347223735 -0.475230664094595 0) // Vertex A0b = 0 //0 (0.482592912464525 -0.337650409564724 0) // Vertex A1b = 1 //1 (0 -0.820243322029249 0) // Vertex A2b = 2 //2 (0.35 -0.500243786407155 0) // Vertex A3b = 3 //3 (0.502294477681098 -0.290000444294613 0) // Vertex A4b = 4 //4 (0.539032001961431 -0.311210907154499 0) // Vertex A5b = 5 //5 (0.58 -0 0) // Vertex A6b = 6 //6 (0.850244450128498 -0 0) // Vertex A7b = 7 //7 (0.850244450128498 0.2 0) // Vertex A8b = 8 //8 (0.58 0.2 0) // Vertex A9b = 9 //9 (0 -0.58 0) // Vertex A10b = 10 //9 (0.332499347223735 -0.475230664094595 0.0577378574479284) // Vertex A0f = 11 //10 (0.482592912464525 -0.337650409564724 1) // Vertex A1f = 12 //11 (0 -0.820243322029249 0) // Vertex A2f = 13 //12 (0.35 -0.500243786407155 0.0607768113697289) // Vertex A3f = 14 //13 (0.502294477681098 -0.290000444294613 0.0872224477773731) // Vertex A4f = 15 //14 (0.539032001961431 -0.311210907154499 0.0936018465870207) // Vertex A5f = 16 //15 (0.58 -0 0.100715858841265) // Vertex A6f = 17 //16 (0.850244450128498 -0 0.147643275896053) // Vertex A7f = 18 //18 (0.850244450128498 0.2 0.147643275896053) // Vertex A8f = 19 //19 (0.58 0.2 0.100715858841265) // Vertex A9f = 20 //20 (0 -0.58 1) // Vertex A10f = 21 //9 ); blocks ( // block0 hex (0 3 5 4 11 14 16 15) (40 140 1) simpleGrading (1 1 1) // block1 hex (4 5 7 6 15 16 18 17) (40 140 1) simpleGrading (1 1 1) //block3 hex (6 7 8 9 17 18 19 20) (40 80 1) simpleGrading (1 1 1) ); edges ( arc 0 4 (0.410121661014263 0.410122205161951 0) arc 11 15 (0.403891001943997 0.410122205161951 0.0712168195145822) arc 4 6 (0.545021515345564 0.198372245564811 0) arc 15 17 (0.536741427823046 0.198372245564811 0.0946419138017175) arc 10 0 (0.100715858841265 0.571188511594785 0) arc 21 11 (0.0991857612164355 0.571188511594785 0.0174891107278166) ); boundary ( inlet { type patch; faces ( (0 11 14 3) ); } outlet { type patch; faces ( (20 9 8 19) ); } fixedWalls { type wall; faces ( (0 4 15 11) (3 14 16 5) (4 6 17 15) (5 7 18 16) (6 9 20 17) (7 8 19 18) ); } front { type cyclic; faces ( (0 3 5 4) (4 5 7 6) (6 7 8 9) ); } Back { type cyclic; faces ( (16 15 17 18) (11 15 16 14) (18 17 20 19) ); } ); mergePatchPairs ( ); Could you please explain me how to fix it ? Is "cyclic" the right BC for my case ? PS: i am using OF-2.2.0 Thanks |
April 10, 2014, 06:30 |
#2 | |
Rep Power: 15 |
If you look here:
http://www.openfoam.org/docs/user/blockMesh.php Quote:
April 10, 2014, 07:13 |
Amin
Rep Power: 12 |
Thanks for ur answer
i changed the definition of my front and Back and i am still not able to run the blockMesh. Code:
front { type cyclic; neighbourPatch Back; faces ( (0 3 5 4) (4 5 7 6) (6 7 8 9) ); } Back { type cyclic; neighbourPatch front; faces ( (16 15 17 18) (11 15 16 14) (18 17 20 19) ); } Code:
Creating curved edges Creating topology blocks Creating topology patches Creating block mesh topology --> FOAM FATAL ERROR: face 0 area does not match neighbour by 136.563% -- possible face ordering problem. patch:front my area:0.00922141 neighbour area:0.0489239 matching tolerance:0.0001 Mesh face:10 fc:(0.435821 -0.389352 0) Neighbour fc:(0.641625 -0.116072 0.111417) If you are certain your matching is correct you can increase the 'matchTolerance' setting in the patch dictionary in the boundary file. Rerun with cyclic debug flag set for more information. From function cyclicPolyPatch::calcTransforms() in file meshes/polyMesh/polyPatches/constraint/cyclic/cyclicPolyPatch.C at line 220. FOAM exiting |
April 10, 2014, 07:41 |
Rep Power: 15 |
Yes, it is the opposite patch.
Try to do make front and Back as type patch first. That should work. Maybe it is just the order of your faces [(0 3 5 4) not opposite to (16 15 17 18)]. It says that the area of one side of the cyclic part is bigger, than the other one. Either try createPatch utility to make both patch-type patches (front;Back) to cyclic ones. [http://www.cfd-online.com/Forums/ope...atchdict.html] ] Or build first one pair of faces [(0 3 5 4) for front and its neighbour for back] in cyclic, and if it works add the next pair of faces to these patches. |
Star CCM Overset Mesh Error (Rotating Turbine) | thezack | Siemens | 7 | October 12, 2016 12:14 |
[ICEM] Negative volume error in hybrid mesh | siw | ANSYS Meshing & Geometry | 4 | September 3, 2014 06:25 |
[ICEM] Orthogonality/Skew issues in 3D unstructured mesh | eddyy19g | ANSYS Meshing & Geometry | 3 | February 13, 2014 10:36 |
How to split the mesh? | Moslem | OpenFOAM Programming & Development | 1 | December 4, 2012 08:43 |
fluent add additional zones for the mesh file | SSL | FLUENT | 2 | January 26, 2008 12:55 |
