Utility to initialize LES Simulation
Like Tree1Likes
  • 1 Post By ScarFace
Old   October 14, 2013, 13:41
Default Utility to initialize LES Simulation
ScarFace
ScarFace is on a distinguished road
Hi Foamers
I want to use my previous RANS results as an initial field for my LES simulation in an external flow problem.
As you know in the ANSYS FLUENT, there is a:
solve/initialize/ init-instantaneous-vel
text command to generate the instantaneous velocity field out of the steady-state RANS results.
is there any analogous utility (available in OpenFOAM or written by users) that generate instantaneous velocity field from the mean RANS results for external flows?
Any help regarding this matter is appriciated
Thanks in advance
ScarFace is offline   Reply With Quote
Old   October 20, 2013, 03:21
Nima Samkhaniani
nimasam is on a distinguished road
you can create two cases: RANS and LES
then using mapField utility to map result from RANS to LES
Usage: mapFields [OPTIONS] <sourceCase>
options:
-case <dir> specify alternate case directory, default is the cwd
-consistent source and target geometry and boundary conditions identical
-mapMethod <word>
specify the mapping method
-noFunctionObjects
do not execute functionObjects
-parallelSource the source is decomposed
-parallelTarget the target is decomposed
-sourceRegion <word>
specify the source region
-sourceTime <scalar|'latestTime'>
specify the source time
-subtract subtract mapped source from target
-targetRegion <word>
specify the target region
-srcDoc display source code in browser
-doc display application documentation in browser
-help print the usage
My Personal Website (http://nimasamkhaniani.ir/)
Telegram channel (https://t.me/cfd_foam)
nimasam is offline   Reply With Quote
Old   October 20, 2013, 09:50
ScarFace
Thanks Nima
I know about mapField utility. since I use the same mesh for both RANS and LES, I can simply replace my last time step from RANS to 0 folder in LES without using mapField.
My problem is that RANS calculations only gave mean values but for LES we need instantaneous values (mean+fluctuations). as I told in the 1st post in ANSYS FLUENT we can add random fluctuations to our previous RANS results by
then this instantaneous values (mean+fluctuations) is used as an initial guess for LES (in 0 Folder).
I know that for channel flow there is a utility called PerturbU that is written by Eugene De Villers for LES initializations.
Is there a similar utility for External Flows?
can mapField utility add random fluctuations to our entire field?
allanZHONG likes this.
Old   October 24, 2018, 19:24
CHEN CHEN
JamesCC is on a distinguished road
Originally Posted by ScarFace View Post
Thanks Nima
Dear ScarFace
Have you been able to sort it out? Cheers.
JamesCC is offline   Reply With Quote
outlet profiles of LES simulation as transient inlet b.c. for LES of a bend pipe Henny FLUENT 0 March 28, 2013 05:02
How to determinate turbulence scale in LES (laminar simulation)? Franciswu21 ANSYS 0 October 22, 2009 13:48
LES simulation of bluff body at Re(d)=1200 arash_nl FLUENT 0 June 1, 2009 14:16
LES simulation of vibrating Wing gtg627e OpenFOAM Running, Solving & CFD 0 September 6, 2007 02:36
LES simulation of sonic jet Jianping Main CFD Forum 0 January 21, 2005 06:52
