September 19, 2013, 01:32 |
Bug? Helyx-OS 1.0.3 for OpenFOAM-2.2.1 ?
Jose Rey
Rep Power: 18 |
I tried creating a buoyantBoussinesqPimpleFoam test case using HelyxOS-1.0.3 for an OpenFOAM-2.2.1 installation and got the following problem: Code:
--> FOAM FATAL IO ERROR: cannot find file file: /home/admin1/Engys/HelyxOS/run/testCylinder/0/alphat at line 0. From function regIOobject::readStream() in file db/regIOobject/regIOobjectRead.C at line 73. FOAM exiting |
September 19, 2013, 14:25 |
Daniel P. Combest
JR22,
yep, this is a change that was made in standard OpenFOAM and is being updated in HELYX-OS. I can walk you through these changes that will be made and also give you a workaround that will get things working again.
That should do it for now but the fix will be out soon to get this taken care of correctly/officially More thorough testing should also be done to make sure this does not affect other solver, so if you find any issues then report back here. Thanks for pointing that out, because this is how the tool improves! |
alphat, helyx-os, openfoam 2.2.x |
ESI-OpenCFD releases OpenFOAMŪ 2.2.1 | opencfd | OpenFOAM Announcements from ESI-OpenCFD | 2 | August 7, 2013 01:26 |
