How to set fvOptions
Like Tree5Likes
  • 2 Post By yurifrey
  • 3 Post By olivierG
Old   August 5, 2013, 05:52
Default How to set fvOptions
Yuri Frey
yurifrey is on a distinguished road
Hello!
I want to set a porous zone using fvOptions in OF 2.2.x, but it seems that the solver doesn't read the file.. I created a mesh with two separate zones and this is the first part of the cellZones file:
FoamFile
    version     2.0;
    format      ascii;
    class       regIOobject;
    location    "constant/polyMesh";
    object      cellZones;
2
zone2
    type cellZone;
cellLabels      List<label>
500
0
1
I create a file named fvOptions into the system folder with:
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
porosity
    type          explicitPorositySource;
    active        yes;
    selectionMode cellZone;
    cellZone      zone2;
    explicitPorositySourceCoeffs
        type DarcyForchheimer;
        DarcyForchheimerCoeffs
              d    d [0 -2 0 0 0 0 0] (5e7 -1000 -1000);
              f    f [0 -1 0 0 0 0 0] (0 0 0);
              coordinateSystem
                  e1    (1 0 0);
                  e2    (0 1 0);
following what is said here:
HTML Code:
http://www.openfoam.org/version2.2.0/fvOptions.php
but the solver (icoFoam) is unable to read it (if I change the values of the coefficients nothing changes in the solution..).
Do I need to specify something more?
Thank you,
Yuri
yurifrey is offline   Reply With Quote
Old   August 7, 2013, 09:39
Yuri Frey
This is the answer I had from fredo490:
I don't have any machine running openfoam next to me now so it's a bit hard to answer.
My guess is that icoFoam has not been updated to consider the fvOption files. The best way to check is to go to the icoFoam source code and check if you find any "+ fvOption" or something similar in one of the equation solved.
I have some source code on my computer but only simpleFoam and pimplefoam are up to date. If you look at the pimpleFoam UEqn.h you will find the following code to solve the momentum equation:
tmp<fvVectorMatrix> UEqn
    fvm::ddt(U)
  + fvm::div(phi, U)
  + turbulence->divDevReff(U)
    fvOptions(U)
The last term is the "fvOptions(U)" file that consider lthe porosity and so on.
Try to find the same for icoFoam... but I think you will not find it because icoFoam behave a bit differently.
Hope it helps you.
I checked it and it is exactly as he said. I had no problems using pimpleFoam.
Tobi and mizzou like this.
Old   November 29, 2013, 09:50
Samuele Z
samiam1000 is on a distinguished road
Hi guys,
I am trying to use fvOption, as well.
What I would like to do is to add a body-force in certain cells of my domain.
Actually, what I did is something like
|  \\    /   O peration     | Version:  2.2.1                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvOptions;
momentumSource
    type            vectorExplicitSetValue;
    active          on;            //on/off switch
    selectionMode   all;       //cellSet // points //cellZone
    vectorExplicitSetValueCoeffs
        injectionRate
            F    ( 0.1335 0 0 );
but I do not understand which are the right entries (I think that doing like what I did, I add a velocity, not a force).
Could you help, please?
Thanks a lot,
Samuele
samiam1000 is offline   Reply With Quote
Old   February 7, 2014, 12:05
Question Where's the porosity field?
Hanniel Freitas
hfsf is on a distinguished road
Hello all,
I'm sorry for such a noob question, but recently I started to model a flow over a porous media in OpenFOAM. In the OpenFOAM website I've stumbled upon a new feature since OF 2.x: the fvOptions dictionary.
The problem is: I cannot see any reference to the porosity of the medium. The example of a fvOptions dictionary configuration (from the very own OpenFOAM website) is:
porosity1
    active        yes;
    cellZone      porosity;
              coordinateSystem
                  e1    (0.70710678 0.70710678 0);
                  e2    (0 0 1);
But there's no mention of the porosity of the medium, as you can see!!!
In a post of Alberto Passalacqua's blog, he posted a similar procedure concerning the version 1.5 of the OpenFOAM. The posted code is as follows:
1
   porosity
       coordinateSystem
                origin (0 0 0);
                e1  (1 0 0);
                e2  (0 1 0);
        porosity 0.5;
        Darcy
                d   d [0 -2 0 0 0 0 0] (-1 1e7 -1);
The porosity field is there, after coordinateSystem definition. What have changed in the 2.2 version? How can I define the porosity of the medium?
Thanks in advance.
hfsf is offline   Reply With Quote
Old   February 10, 2014, 07:01
Olivier
olivierG is on a distinguished road
For pressure/velocity resolution, you don't need the porosity info (at least with Darcy model), only permeability.
However you need it for heat transfert, but in this case just add another fvOption for the heat transfert part (like "constantHeatTransfert" of "effectivenessHeatExchangerSource").
regards,
olivier
olivierG is offline   Reply With Quote
Old   February 22, 2016, 19:14
openfoammaofnepo is on a distinguished road
Dear Olivier,
For fvOptions, for those tutorials without the dictionary "fvOptions", the "fvOptions" related terms appears in the source files of the solvers actually are useless. These terms are only active when we specify the parameter in the fvOptions dictionary. Is what I am saying correct? Thank you so much.
openfoammaofnepo is offline   Reply With Quote
fvoptions
TimeVaryingMappedFixedValue irishdave OpenFOAM Running, Solving & CFD 32 June 16, 2021 07:55
Porous region set braket FLUENT 4 November 18, 2010 03:09
What value shall I set for the Convergence criteria? steventay CFX 7 May 14, 2010 13:44
Install problem in linux navaladi OpenFOAM Installation 11 July 17, 2008 03:24
Ibm java gcc rrr OpenFOAM Installation 2 December 30, 2005 05:18
