HelyxOS Boundary Conditions
Like Tree1Likes
  • 1 Post By chegdan
Old   July 30, 2013, 11:41
Default HelyxOS Boundary Conditions
HHOS is on a distinguished road
Hello!
I am using OpenFOAM v2.2.0 since a couple of weeks ago, and I am using HelyxOS to do the setting up of the case. The workflow is:
  1. Import a Fluent mesh into OpenFOAM
  2. Put some required dummy files in the case folder (maybe not so dummy, but yes as far as I know...)
  3. Load the case with HelyxOS.
  4. Set the whole case up.
  5. Change what I need to in files such as ControlDict.
  6. Run the case with OpenFoam from the terminal.
The problem is that I don't really understand all the Boundary Conditions options. I have been trying to find a document or so where they are explained, but I didn't find any...
Regarding the Velocity:
  • Fixed Value
  • Cylindrical Inlet Velocity
  • Surface normal Fixed value (why can't I put possitive values?)
  • Flow Rate Inlet
  • Pressure inlet Velocity
  • Pressure directed Inlet Velocity
  • Pressure inlet outlet Velocity
  • Pressure Directed Inlet Outlet Velocity
  • Freestream
  • Inlet Outlet Velocity
  • Zero gradient
I can roughly understand some, but all which I wrote in Bold letters, I have no idea. And what is the difference between Fixed Value and Freestream? The Zero gradient is not completely clear either.
Regarding the Pressure:
  • Fixed Value
  • Total Pressure
  • Freestream Pressure
  • Buoyant Pressure
  • Zero Gradient
Here I don't understand most of them... And if I want to set the atmospheric pressure in the boundaries, how can I do? Because I have to write a m^2/s^2 value...
It is a long and hard question, I guess... THANK YOU VERY MUCH FOR THE LITTLE HELP YOU MAY GIVE HERE
HHOS is offline   Reply With Quote
Old   July 30, 2013, 16:00
Daniel P. Combest
chegdan will become famous soon enoughchegdan will become famous soon enough
Hey There and welcome to the forum!
The best thing to do is look through the source code (especially the top of the .H files) for each BC and read the descriptions. If you have OpenFOAM correctly installed, you can go to
$FOAM_SRC/finiteVolume/fields/fvPatchFields/derived
You might want to look over some slides I gave at the 8th OpenFOAM workshop located here. it is a basic training presentation on HELYX-OS. I am traveling today so I don't have time to answer your question in more depth.
Disclaimer: I work for the company that produces HELYX-OS
HHOS likes this.
chegdan is offline   Reply With Quote
Old   July 31, 2013, 04:45
Thank you very much for the advice!
I have checked the .H files and, even if not in every case, they helped me to understand the boundary conditions a bit. I have also seen the PPT presentation; quite interesting. Anyway it would be nice to have some example where the BC can be usually applied; some seem very similar, but I know that the BC thing is very tricky... and I don't know if the results would change much; I guess that it may be so.
Again, thank you
boundary conditions, helyx-os
Question about heat transfer coefficient setting for CFX Anna Tian CFX 1 June 16, 2013 07:28
symmetry boundary conditions in cfx lost.identity CFX 41 May 22, 2013 08:21
Low Mixing time Problem Mavier CFX 5 April 29, 2013 01:00
[Netgen] boundary conditions and mesh exporting vaina74 OpenFOAM Meshing & Mesh Conversion 2 May 27, 2010 10:38
[Commercial meshers] Trimmed cell and embedded refinement mesh conversion issues michele OpenFOAM Meshing & Mesh Conversion 2 July 15, 2005 05:15
