Airfoil lift and drag understimated
Like Tree1Likes
  • 1 Post By Naruto
Old   July 25, 2013, 12:58
Default Airfoil lift and drag understimated
Kio
Kio is on a distinguished road
Hello everybody, I am quite new in CFD and in particular in OpenFoam.
I use the 2.1.1 version and I try to simulate the behaviour of a 4415 airfoil at different angle of attack.
There were no problem to obtain a "correct" trend of Cp (so pressure) according to experimental values, but lift and drag are understimate of 50%.
I guess the error can be associated to the BC of k and omega in k-w model and nuTilda in SA, because I choose them according to the parameters used in OpenFoam tutorial.
I have a freestream velocity U=100 m/s, solver sonicFoam, k=150 and omega=462 at the inlet fot k-omega, and nuTilda=0,14 for SA, wall_function for patches type wall.
Another question is about the function for calculate forces in controlDict file, I set this for angle of attack=0:
functions
{ forces
type forceCoeffs;
functionObjectLibs ( "libforces.so" );
outputControl timeStep;
outputInterval 1;
patches (profile_wall)
pName p;
UName U;
log true;
rhoInf 1.225;
CofR ( 0 0 0 );
liftDir ( 0 1 0 );
dragDir (1 0 0 );
pitchAxis ( 0 0 1 );
magUInf 100.0;
lRef 0.1254;
Aref 0.01292;
For angle of attack >0 I have to set the correct directions for lift and drag or the function calculates the force resulting on the airfoil and from that split lift and drag?
Thanks everybody
Kio is offline   Reply With Quote
Old   July 25, 2013, 14:54
Kio
something that could help to understand the problem with k and epsilon (or omega, with all models are the same..)
Old   July 27, 2013, 04:42
bscphil's Avatar
Phillip
bscphil is on a distinguished road
Hey Kio,
is your case 2D or 3D, because there are different definitions for lift and drag coefficients?
Just set the "lref" and "Aref" values both to 1 and after simulating calculate your coefficients with your definition.
For angle of attack > 0, i think you don't have to set new directions for liftDir and dragDir, beacause you want the forces in global coordinates and not in local.
To your boundary conditions for the turbulence values:
  • what is your turbulence intensity and turbulence length scale ??
You can upload your case, then we can look at your settings!!!
Greetz, Phil.
bscphil is offline   Reply With Quote
Old   July 27, 2013, 05:42
Kio
Hi, sorry I forgot it. It is a 2D case, the turbulence intensity is 10% of the velocity and turbulence lenght scale is 0.0965 .
Here the case setup for the k-epsilon model.
thanks to all
Old   July 27, 2013, 10:27
bscphil's Avatar
Phillip
thanks to all
Thanks for the case. I've two more questions
  1. What is your airfoil chord length? --> i think 0.1254m?
  2. Do you have theoretical or experimental values for lift and drag coefficients?
Old   July 27, 2013, 14:20
Kio
Yes, the chord length is 0.1254 m. The values are experimental, from a report NASA. I check that the flow conditions are the same.
Old   July 29, 2013, 14:45
Naruto is on a distinguished road
Hello Kio,
You did not provide the /constant folder. I faced a similar kind of problem like you a few months ago. The solution of my problem was quiet obvious. I made mistake in system/forceCoeff file. I did not take into account the length in z-direction. What I am meaning is that you have to find out the reference area like this: Chord_length * Height of extrusion in z-direction.
Anyway check the small detail and keep us posted. Normally a tiny misplaced setting plays the main role in this kind of error. Good luck.
hideonramas777 likes this.
Happy Foaming
Naruto is offline   Reply With Quote
Old   July 30, 2013, 04:51
Kio
No the reference area is correct, I calculated area in the way you tell me.
The flow simulated is correct, I cannot understand.
The cd and cl coefficient are non dimensional, so I could compare with the coefficients from the report also if the airfoil scale is different
I cannot provide you the constant folder because is too big
Old   September 11, 2013, 05:18
Kio
Hello everybody, after one month I do not find the problem.
I try different meshes and turbulence models but the problem is still the same, pressure field is correct but cl and cd are understimate.
I do not understand if the direction of lift and drag are simply (0 1 0) and (1 0 0) or inclinated with the flux. However also with an angle of attack of 0° cl is understimate.
There is another problem with an angle of attack > 0° with the coefficient cd that is negative. I attach an image to show you the reference system, how can I set the lift and drag direction? I think (0 -1 0) and (1 0 0) but the cl is positive and understimate of 20-30% and cd is negative and in any case too high. I attach also the log file of a case with angle=6° and k-omega model.
Please help me! I have to present the case within two weeks!
Old   September 11, 2013, 08:15
Kio
A little doubt: I read all the threads about airfoil simulation on the forum and I observed that in all simulations the airfoil mesh is divided in two patches, top and bottom, but only one coefficient is shown in the log file. How the library choose on which patch calculate forces?
Old   September 11, 2013, 08:57
Hello kio. I am uploading my casefiles. I have validated the results with real data. Although I have simulated for incompressible flow using simpleFOAM. But still I think you might get an idea. Good luck.
https://dl.dropboxusercontent.com/u/...8/NACA0015.rar
Happy Foaming
Old   September 11, 2013, 10:56
Kio
thank you very much Naruto, I tried also with simpleFoam and you boundary conditions (my original solver was sonicFoam) but the result remains the same, the cl is too low and cd too high.
Are you sure your results are right? I find a forceCoeffs.dat in your case uploaded, but with an angle of attack of 13° specified in the file 0/U also your cl was too low!
For example the coefficient with xfoil are here:
http://airfoiltools.com/airfoil/deta...il=naca0015-il
Old   September 11, 2013, 13:45
Yes I am sure that my data are ok. I checked them.
But I am saying again they are for incompressible flow.
Happy Foaming
Old   September 11, 2013, 14:37
Kio
ok, thanks again. Probably the problem is related to the compressible flow
Old   September 13, 2013, 07:41
Kio
I try with a mesh generated automatically by a script found here
https://www.hpc.ntnu.no/display/hpc/...l+Calculations
Although the pressure field is not accurate like that of the previous mesh, cl and cd are calculated exactly! y+ is between 1000 and 5000, I think my previous mesh was better because y+ was between 10 and 30, but the forces were not right.
I cannot explain that...
Old   October 1, 2016, 14:48
jiyou
Freestream is on a distinguished road
Hello Kio, do you have any insight to this problem?
I'm doing a validation for NACA 0012 and 4412, i am facing the same problem as well.
Hope you may give you advise...
Freestream is offline   Reply With Quote
lift & drag coefficient on airfoil n. natik FLUENT 8 March 31, 2015 20:02
Problem with restart solution in shape_optimization.py robyTKD SU2 Shape Design 21 May 29, 2013 10:26
airfoil lift and drag coefficient amir_14 FLUENT 5 January 1, 2013 09:30
Symmetric NACA Airfoil Lift and Drag Data jrider22 Main CFD Forum 3 April 15, 2010 05:59
Airfoil Lift and Drag Dr. Laith K. Abbas Main CFD Forum 8 July 2, 2005 04:32
